Here we go again Golden Eagle and head gaskets?
they makes 2 differnte gasket, HP is non o-ringed and the other one is o-ringed, or it may be the other way around, but they do make both
stan
stan
I have the fire extinguisher ready.
Lots of people have success with either an over-bored stock hg, copper sprayed(2-3 coats) or the Cometic hg without the fire-ring (again copper spray is a good idea.)
This is for O-ringed blocks.
They both work but you just have to make sure everything is done correctly.. correct torque on head bolts, copper spray..
FYI:
I tried the cometic MLS (one w/out fire-ring) w/ my o-ringed block and it didnt work. Now I am removing my o-rings, and going to try the cometic HP gasket and it should work as I was told by GE.
