6th gen h22a swap need nelp fast
im tring to start up my car for the first time sence the swap it wont start i think there is a security device or a immolbileizer i need to know how to bypass it or get it to start please help
i,m using the obd1 ecu when I use the obd1 ecu with the conversion harness Itern on the key but I don't hear the fuel system working. when i put the obd2 ecu in i hear the fuel system working but she still wont fire. it will crank with both ecu's, so yea i still need help.
dude im stoked my car fired for the first time last night i hope to test it out in the next couple of days but a new problems, I have no preacher in my clutch when I did the swap I never detached the lines and I have fluid
good luck with that, did you get the fuel system to work by fixing the conversion harness? because if you use the version 2 on made for civic si it wont work because the fuel pin is relocated to a16 with cars that have the immobilizer, you will need the one that works for the 00+ gsr.
buffgsr
13
May 1, 2010 02:12 PM
silentbeatz
Dec 16, 2008 09:44 AM
DeviousCTR
14
May 4, 2006 03:28 AM
