To ppl have Field's SFC-Vtec Controller
i got it....
i have been playing with it till i get it on the dyno...
i currently have found out that if i start to lean it on 1-4k rpms its a bit better
-3 @ 1k
-2 @ 2k
-1 @ 3k
0 @ 4k
+1 @ 5k
+2 @ 6k
+3 @ 7k
works ok for me.... i am still tryin to find out how to have it lean on bottom end and rich it a lil more on top end without having a big jump on the readins and causing my ecu to trow a MAP sensor code
-3 @ 1k
-2 @ 2k
-1 @ 3k
0 @ 4k
+1 @ 5k
+2 @ 6k
+3 @ 7k
The Field's was alot less "tunable" than the Shogun tuner from Hypertech I used to have. When I had them both on the car, I set VTEC and killed the speed cut on the JDM ecu with the Field's unit, and tuned the car for timing and fuel and rev limit on the SHogun.
I picked up 33 HP on the dyno from tuning my ITR Cams/Intake Mani/TB'ed b16a.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid »</TD></TR><TR><TD CLASS="quote">I picked up 33 HP on the dyno from tuning my ITR Cams/Intake Mani/TB'ed b16a.
Thas comforting to hear since I have a similar setup
Most of the people I have talked to found leaning it out under VTEC and more fuel after VTEC gives good results, best to only alter it by a small amount. Let me know if your SFC starts playing up, im interested to know how many people have had a similar problem to me.
</TD></TR></TABLE>Thas comforting to hear since I have a similar setup
One thing to keep in mind when using a Fields or VAFC controller and stock injectors. You can't add very much fuel at all, because of the injectors being maxed out. Most tuners would prefer a fuel press reg to increase overall, and the controller to lean it out where necessary. Every motor is different.
I always wondered about increasing the fuel as rpms go higher. Is this really desirable, because doesn't the ecu automatically increase fuel at a linear rate as rpms increase therefore it would make more sense if say u had -2% across the band?
I had a Fields b4 and i did do gradual increase richening, but now I have a VAFC and am using a -3% across the band.
Insights anyone into this issue?
soon enough i will buying a Dyno tune Hour...
when i get it done well see how the Z6 behaves across the powerband...
best way to do it is with dyno tunnig with a wideband.....
well see how good it behaves....
ill keep u guys posted...
Excelerate
Jun 25, 2003 01:15 AM
yellowcrx88
Jun 2, 2003 05:53 PM
CimorelliCRX
May 15, 2003 06:16 PM
