i've decided to just go obd1.here's my ?'s
Old May 29, 2003 | 04:55 PM
crx1856's Avatar
Default i've decided to just go obd1.here's my ?'s
well after trying to find a way to run obd0 in my turbo b16 crx w/hondata2b, i've decided to just go obd1.here's my q's
1.can i use the 2b or should i sell it and get s100 or s200?
2.what ecu should i go with?
3.i know i need the conversion harness and obd1 dist. what else do i need to do?
4.how many o2 sensors does the obd1 ecu's use?
Old May 29, 2003 | 05:07 PM
poison's Avatar
Default Re: i've decided to just go obd1.here's my ?'s (crx1856)
1) Yes you can.
2) I would go with a chipped P28 ECU.
3) Fuel injectors as well as the dist
4) Just one. and that is on the header.
HTH
Old May 30, 2003 | 03:53 AM
h22 ef's Avatar
Default Re: i've decided to just go obd1.here's my ?'s (poison)
you dont have to change injectors as long as you are still using the resistor box
lsvtec hf
Engine Management and Tuning
Jan 21, 2009 12:02 PM
sfwdcrx
Dec 22, 2007 07:38 PM
marks1989civic
Feb 21, 2007 10:56 AM
rice is nice
Aug 22, 2005 09:08 AM
