Hondata and Jackson Racing releases Big boost JR kits
Old May 29, 2003 | 04:43 PM
Hondata's Avatar
Default Hondata and Jackson Racing announce the Big Boost JRSC kits
JRSC Big Boost kits
We are pleased to announce that we now have pre-tuned maps available for Jackson Racing supercharger kits fully mapped for all boost levels up to 11psi. Kits are available for the following engines:
B16A - 99-00 Civic SI, 93-97 Del Sol VTEC
B18C - 94-01 Integra GSR
B18C5 - 97-01 Integra Type R
D16Z - 92-00 Civic EX
H22A - 92-01 Prelude
Complete supercharger kits or upgrade kits including pulleys, belts, ECU, injectors, Hondata and map are available through Moss Performance.
Every engine was extensively tested for part and full throttle operation at varying levels of boost. These are our most comprehensively tuned maps to date.
Extensive information available from: http://www.hondata.com/jrsc_big_boost.html
Modified by Hondata at 5:56 PM 5/29/2003
Old May 29, 2003 | 04:53 PM
done's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (Hondata)
very nice
Old May 29, 2003 | 05:09 PM
jinxproof99's Avatar
New User
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (Jordo)
thats a step in the right direction for JRSC's.
Old May 29, 2003 | 05:20 PM
littlebluecrx's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (jinxproof99)
h22 looks like it was meant for a blower. Jason
Old May 29, 2003 | 05:28 PM
TREVER's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (littlebluecrx)
now if you can make it easy to install too.
Old May 29, 2003 | 05:36 PM
Sonny's Avatar
Cool.
Sonny
Old May 29, 2003 | 05:38 PM
LostLude's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (TREVER)
why do I not see anything for the prelude at MOss's?
Old May 29, 2003 | 06:00 PM
zip's Avatar
zip
Old May 29, 2003 | 06:36 PM
Mikes01GSR's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (zip)
Very Impressive numbers!!!
Old May 29, 2003 | 06:46 PM
95GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlebluecrx &raquo;</TD></TR><TR><TD CLASS="quote">h22 looks like it was meant for a blower. Jason</TD></TR></TABLE>
Yep ... look at this one:
https://honda-tech.com/zerothread?id=509715
Old May 29, 2003 | 07:15 PM
MachAF's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (95GS-R)
nice..very nice.....just wait for all the supercharger haters to come and shoot their mouth off.
Old May 29, 2003 | 09:42 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (MachAF)
Looks good..just what i need...a new base map..
Old May 29, 2003 | 10:06 PM
SiRkid's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (Blue-Civic-Hybrid)
awesome....imagine this with a nice i/c!!!!!!
Old May 29, 2003 | 10:22 PM
Spunkster's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">awesome....imagine this with a nice i/c!!!!!! </TD></TR></TABLE>
&lt;whistling non-chalantly&gt;
Old May 29, 2003 | 10:26 PM
jabroni95gsr's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (Spunkster)
To be honest, the #'s seem low. Only 245 on a gsr with 10psi??? That doesn't seem right. Over on the jrsc board, there are members who are reaching 230's with 6psi. Go figure.
Old May 29, 2003 | 11:00 PM
Sonny's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (jabroni95gsr)
Well, ya gotta consider that those engines are probably not tuned to the ragged edge of performance. There is definitely a tradeoff between power and safety and they've probably tried to idiot-proof the setup to some extent.
Sonny
Old May 30, 2003 | 12:11 AM
AbaZ's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (Sonny)
When I read this thread, all I can think about is drinking a
Old May 30, 2003 | 12:31 AM
mskibbz-T's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (AbaZ)
very respectable
Old May 30, 2003 | 04:57 AM
b20turboic's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (mskibbz-T)
if they read 230 at 6psi they may have also used a deferent dyno type thus giving a higher number ... all dynos very
Old May 30, 2003 | 08:46 AM
GirlNALude's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (b20turboic)
Im absolutely sure for the Prelude that the gas it was tuned with was 91 octane. Im pretty positive that was what the other cars were tuned with as well. Thats excellent reliable hp at only 91 octane because thats the highest california gas goes (unless you go pick up some 100 oct. at a 76). Some people may probably be able squeeze out more hp if their area has 93 or even 94 octane.
Old May 30, 2003 | 09:43 AM
Hondata's Avatar
Be aware that many factors affect boost levels in JR superchargers.
- Cam timing will change boost levels.
- Boost drops 1-2 lb after vtec engages.
- A cold air intake will add 0.3-0.5 lb of intake manifold pressure (boost).
- A restrictive exhaust will increase boost levels and also reduce power considerably. In the case of the Prelude charted here, removing the cat, and replacing the rear muffler (which had a 1.75 inch exit!) would both decrease the boost and increase the power.
So when people say their JR system was dynoed with a 6 lb kit, it could be from anywhere from 5-8 lb boost. To be sure you have to datalog it.
What is not apparent in these charts is the bottom end torque and part throttle to boost improvement.
Old May 30, 2003 | 10:01 AM
Silverbeast's Avatar
When will these maps be available to the Dealers ?
Thanks
Old May 30, 2003 | 09:09 PM
Hondata's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (HoustonSi)
As of now. Email sales with your dealer info. The files will be sent via return email.
Old May 30, 2003 | 10:22 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
whoa whoa whoa, hold the phone... did i miss something here.... they offer a supercharger for the 92 up prelude (4th gen) vtec? is this just a typo or what?
Old May 31, 2003 | 12:07 AM
Hondata's Avatar
Default Re: Hondata and Jackson Racing announce the Big Boost JRSC kits (PreIudeSI)
The post was meant to indicate the engine for which there are maps rather than the car. If you can get the supercharger to fit we can supply the engine management.
