racinghart CPRs..
Theres a set of springharts in 16x7 with a 42mm offset for sale if thas the one you are looking for.
http://www.wheelchoice.com/wheel02.htm
I don't think you'll have any problems clearing the Spoon calipers w/ a 16" wheel w/ +42mm offset. On a 15" wheel with the same offset yes but 16" I wouldn't worry about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si »</TD></TR><TR><TD CLASS="quote">I don't think you'll have any problems clearing the Spoon calipers w/ a 16" wheel w/ +42mm offset. On a 15" wheel with the same offset yes but 16" I wouldn't worry about it.</TD></TR></TABLE>
you gotta think about the spokes though...whether or not they will hit them.
I'm not sure what racing hart CPRs are, but I have a set of Sprint Hart CP-035 on my ITR...and they have a 45mm offset, and they fit over the stock calipers, which are about the same size as the spoons, and acutally have more clearance than my factories did. I know it's a pretty terrible picture of my front wheels, but I didn't have any better at the time....but even in these pics, you can see how much caliper clearance there is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaj23 »</TD></TR><TR><TD CLASS="quote">I'm not sure what racing hart CPRs are, but I have a set of Sprint Hart CP-035 on my ITR...and they have a 45mm offset, and
Racing Hart CPR do not have a generous spoke to hub clearance like your CP-035.
Stock calipers is nowhere near the same dimension as the Spoon calipers (width-wise). So you really can't judge whether a certain wheel will clear Spoon calipers by OEM calipers comparison.
I personaly do not think the CPR will clear.
Well....my friend John has the spoon calipers, which fit behind factory 15" wheels quite well, and although they do have a larger offset, visually looking at the amount of clearance his has, and the amount mine have, there looks to be plenty....if you want, if I can convince him to let me put one on my car for a couple minutes to see if it fits and how much clearance I have...assuming it'll help....
We have a power brake bleader and three lifts at the shop, so it's not that big of a deal....cause now you got me curious, cause I was thinking of getting similar calipers....
Have any pics of CPRs????
Have any pics of CPRs????</TD></TR></TABLE>
i have cpr's and my spoon calipers did not fit. actually it wasn't even close, i needed a 10mm spacer but by then the wheel was sticking out
note: i do not have a itr, but a ek with 5 lug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplehazek4 »</TD></TR><TR><TD CLASS="quote">i have cpr's and my spoon calipers did not fit. actually it wasn't even close, i needed a 10mm spacer but by then the wheel was sticking out
note: i do not have a itr, but a ek with 5 lug</TD></TR></TABLE>
i guess i'll be sticking to my stock ITR calipers. thanks for the info.
