Emblem Removal Question
Old May 29, 2003 | 03:13 PM
Integra21's Avatar
Default Emblem Removal Question
first off - whats the best was to remove them - is it you head the emblem with a hair dryer and then use floss to separate the glue from the car? then use goo-gone or some cleaner to get the excess glue off?
also - i realize that there will be two small holes left from the emblem - my question is, does honda or anyone for that matter know of any small plugs that will fit in the holes? i dont want to spend the money to get it "shaved"
Thanks, Brad
Old May 29, 2003 | 04:33 PM
JDMC5's Avatar
Default Re: Emblem Removal Question (Integra21)
What I did what I sprayed WD 40 and let it sit for like 5 min. Also Gas works well to eat away @ the plastic goo holding the emblum on. Just warning you if you leave WD-40 or gas on there too long and your paint will go bye bye, so if you do it, 5-10 min max then spray it off after your done. If not a heat gun (Or a hair drier) works well to. When you take it off, there will be 2 holes. You need to get them covered, its a good place for rust to start. For the time being you can just use plugs. I had my car painted and had the holes shaved.
Old May 29, 2003 | 05:46 PM
NINE TRE's Avatar
i used heat gun/dryer, been careful when i was flossin...emblem will easily come off, then use some goof off or something to get the remaining glue on the surface...
you will need to shave it to cover the holes.
Old May 30, 2003 | 06:10 AM
Integra21's Avatar
Default Re: Emblem Removal Question (drunkn_tyger)
thanks guys- but im real tight on money - how much would just those two holds be to be shaved?
Old May 30, 2003 | 06:29 AM
arsenaldragster's Avatar
dont worry about the holes.. its not worth bringing it to the body shop for those two small holes.. leave em and spend money more wisely
Old May 30, 2003 | 06:38 AM
Integra21's Avatar
Default Re: Emblem Removal Question (arsenaldragster)
arsenaldragster - thats exactly what i wanted to do - but im now worried about rust- is there anything can do to prevent that? lots of wax - keep them clean? what?
Thanks Brad
Old May 30, 2003 | 06:57 AM
IntEGNYC's Avatar
Bondo filler and soem touch up paint... under $15
Old Jun 1, 2003 | 02:32 PM
Integra21's Avatar
Default Re: Emblem Removal Question (IntEGNYC)
has anyone tired the bondo and touch-up paint? how does it come out?
HOUSTONb
Paint and Body
May 1, 2007 11:12 PM
.water
May 26, 2005 10:22 PM
danteisme
Apr 4, 2005 07:22 AM
jond
Jul 7, 2002 08:00 AM
Got-VTEC
Oct 3, 2001 01:23 PM
