well clutch is gone
Well I have been feeling grinding threw out all my gears and know it can't be every syncro, so I decided to take of my tranny and check it out.
As I looked at the clutch and flywheel I noticed unnecessary wear on the flywheel and clutch.
I had ny neighbor check it to see if he could spot anything else. Well he did, he noticed when they resurfaced my flywheel they took to much off causing the springs on the clutch to run on the flywheel bolts, which will cause instant chatter expecially at high RPMS.
he noticed small chunks taken out of the springs and they were loose too, I don't know if you can see then in this picture. Well all I have to say is RIP Act clutch, it only had 8,000 miles on it. now I get to put on my Clutchmasters Flywheel and look for a new clutch, what would you guys recommend?
