Will 13" Lenso wheels fit over stock 99-00 Si brakes/calipers?
From: see my earring from a MILE, bling bling, Va, USA
I want to possibly run the car, and my friend has a set of lenso's hes willing to let me borrow, but he's saying that they wont fit...Im thinking they will...
Isn't the offset... only the measurement separating the studs from each other? For example a civic, and integra are 4x100... Preludes are different, and type R's are obviously 5 lug so they’re different. I don't think they will fit over the caliper, but I'm not for certain... I have a pair of 13-inch Bogarts that I have to use a spacer to push the wheel out to clear the caliper. I've never tried it without the spacer. Maybe I should try it...
Let us know if they fit...
I was looking at your setup below in your signature... and we're running pretty much the same setup on the same car. I have yet to run my car at the track. I'm running 12psi on the street, and plan on boosting 15 psi at the track... Just wondering if you have timed your car, and if you have dyoed it yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic »</TD></TR><TR><TD CLASS="quote">Isn't the offset... only the measurement separating the studs from each other? </TD></TR></TABLE>
You're thinking of the lug pattern. The offset is the distance from the centerline of the wheel to the mounting surface. For example, a wheel with +40mm offset has its mounting surface pushed 40mm toward the face of the wheel, which pushes the entire wheel further into the wheel well. A negative offset would mean the wheel is pushed out of the wheel well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">
You're thinking of the lug pattern. The offset is the distance from the centerline of the wheel to the mounting surface. For example, a wheel with +40mm offset has its mounting surface pushed 40mm toward the face of the wheel, which pushes the entire wheel further into the wheel well. A negative offset would mean the wheel is pushed out of the wheel well.</TD></TR></TABLE>
That's right, thanks! So do you know if I put my bogarts on with no spacer will they fit?
thats primarily what im asking. If the actual diamer of the wheel (13") is big enough to fit over my calipers? I know that 14's are kinda tight..
Lenso 13's will fit. Any other manufacturer should specify, but (13") Bogarts do require extended studs and spacers to fit over the calipers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 »</TD></TR><TR><TD CLASS="quote">Lenso 13's will fit. Any other manufacturer should specify, but (13") Bogarts do require extended studs and spacers to fit over the calipers.</TD></TR></TABLE>
My 13 Bogarts came with spacers, and they fit fine. I have yet to install extended wheel studs though.
Oh, ok. I assumed you would have to extend your studs for the bogarts. My bad. That's also cool that they come with spacers.
Yellow Dragon
Honda Fit
Nov 19, 2006 10:01 PM
Jawad.
Apr 24, 2003 09:16 PM
