which cam should I pick...
Old May 29, 2003 | 07:38 AM
d16a6's Avatar
Default which cam should I pick...
Exospeed SR909 A6 vs. Crane stage 2 vs. Gude 2624
I have a Civic Si with I/H/E. My plans are to go for a high 14´s on the 1/4mile.
which cam should I pick? Any experience?
Old May 29, 2003 | 08:05 AM
DJ_SaNdOz's Avatar
Default Re: which cam should I pick... (d16a6)
have you actually discussed your goal w/ Wil at Exospeed or anyone at Crane or Gude? I would suggest calling or emailing them to see what their thoughts are. At least that way you get an informed discription of what the products are capable of. GL- I would say Exospeed because I have chatted w/ Wil on several occasions about different things & the customer service seems to be outstanding, but you'll need to check on the performance & what suits your needs.
Old May 29, 2003 | 08:11 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
https://honda-tech.com/zerothread?id=427814
Exospeed SR909 A6
SR909 A6
Advertise Duration: Int=268 / Exh=256
Duration @ .050: Int=NA / Exh=NA
Lobe Separation: NA
Gross lift: 398/388
Crane stage 2
251-0012
Advertise Duration: Int=232 / Exh=234
Duration @ .050: Int=206 / Exh=208
Lobe Separation: 108
Gross lift: 394/386
Gude 2624
2624
Advertise Duration: Int=241 / Exh=228
Lobe Separation: NA
Gross lift: 415/421
the exospeed is around $200...the crane is about $310 with the $20 rebate they have...and the gude is around $250. exo and gude need cores too.
never seen dynos of any so any guess is good. youll need alot more than a cam to hit the 14s.
xkrazyxjbrkerx75
Nov 4, 2009 10:48 PM
hulk_22
17
May 12, 2006 10:58 PM
H2nr
Feb 16, 2005 01:55 PM
RACING INTEGRATION
Mar 19, 2003 04:40 AM
