Flashing oil light... HELP!!!
Old May 29, 2003 | 05:43 AM
HondaRue's Avatar
Default Flashing oil light... HELP!!!
A co-worker of mine has a 91 accord se that has a flashing oil light problem. It does not come on every time he drives it and sometimes it will go days without coming on at all. He changed the oil and filter, tested verified oil pressure, and installed a new integrated control unit and none have fixed the problem. If any of you have any clues, we would greatly appreciate the help.
Old May 29, 2003 | 05:45 AM
carolinaACCORD's Avatar
Default Re: Flashing oil light... HELP!!! (HondaRue)
Oil pressure sending unit, maybe?
Old May 29, 2003 | 12:59 PM
HondaRue's Avatar
Default Re: Flashing oil light... HELP!!! (carolinaACCORD)
We already installed a new one and still it flashes.
Old May 29, 2003 | 01:15 PM
JimBlake's Avatar
Then it sounds like the wiring is shorting to ground somewhere. That's all the pressure switch does, is close the circuit to ground.
Old May 29, 2003 | 02:47 PM
HondaRue's Avatar
Default Re: Flashing oil light... HELP!!! (JimBlake)
I'll pass on the suggestion to him and see if he has checked the wiring yet. Thanks for the help!
Old May 29, 2003 | 05:59 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaRue &raquo;</TD></TR><TR><TD CLASS="quote">We already installed a new one and still it flashes.</TD></TR></TABLE>
Try hooking up a manual oil pressure guage. That is the best way to see what you are actually getting for oil pressure. It MAY be something as easy as a wire problem ... but you will not really know unless you check the pressure out. How many miles on the engine?
96_RHD_EK
Apr 17, 2008 02:06 PM
shrirag
Apr 11, 2007 09:55 AM
FastAzzDA
Oct 20, 2006 03:07 PM
badboy409
Jul 2, 2005 10:24 AM
Sick79
Jul 31, 2004 08:23 PM
