89 crx hf with b18c1 HELP PLEASE!!!!!!
Old May 28, 2003 | 09:57 PM
dotcom's Avatar
Default 89 crx hf with b18c1 HELP PLEASE!!!!!!
I have a b18c1 in my crx hf . When I go to work in the morning I have problems getting to run, it seems like it is getting no gas it will sputter and when i put my foot on the gas peddle it doesn't help . After a couple of starts it will run but not that great until I am about 5 miles down the road and it will run ok, I just had it done monday I am thinking it is the fuel pump, what do you all think?
Old May 28, 2003 | 10:17 PM
Mentat Ghola's Avatar
any codes?
Old May 28, 2003 | 10:30 PM
Slurp56's Avatar
Default Re: (The B Man)
Not fuel pump. My 88DX pump is working fine for my GSR
As just mentioned, any codes? best way is to get under there with a schematic and continuity tester (multimeter)
Old May 29, 2003 | 06:11 AM
1bad-eg's Avatar
Default Re: 89 crx hf with b18c1 HELP PLEASE!!!!!! (dotcom)
What ecu are you running. My buddy has a j-spec ecu with a mugen chip and it runs like **** until it warms up.
Old May 29, 2003 | 08:16 AM
dotcom's Avatar
i don't have a check light on but i didn't check for codes . The thing is that it just does it in the mornings when i go to work and when i come out for like lunch 6 hours later it runs just fine . I have a pr3 ecu with a rev hard chip
Old May 30, 2003 | 10:49 AM
GreenD's Avatar
Default Re: (dotcom)
ttt
Old May 30, 2003 | 08:02 PM
Fobtions's Avatar
Default Re: (GreenDestiny)
need more info. what injectors are you using??
Old May 31, 2003 | 04:36 PM
bigblockEG's Avatar
Let me guess///you are using the pr3. WIth a custom program. I have 2 friends that have similar set-ups. Car needs to be at operating temp, 190-200 before it will run right. Thats the way their programs are ....cant do nothing about it unless your obd-1, in that case I dont know what the problem is... If you are not OBD-1, then i think that is your problem..
ryanmh22
Jun 20, 2012 08:09 PM
UmbraDc2K
Feb 14, 2008 08:58 PM
furiousbob
18
Mar 22, 2006 02:56 PM
dlric
Aug 4, 2002 06:03 AM
