OK to run without thermostat?
Old May 28, 2003 | 08:40 PM
1CiViC1's Avatar
Default OK to run without thermostat?
what would happen if i ran without the thermostat? Pros and cons please!! thanks
Old May 28, 2003 | 08:49 PM
MidoriEK4's Avatar
Default Re: OK to run without thermostat? (1CiViC1)
um your engine wouldnt cool. thermostat opens at a certain temp which allows coolant to run through the radiator. with the coolant in the radiator the fan kicks on cooling the coolant. so in conclusion you do need the thermostat. its like a circle of cooling.
Old May 28, 2003 | 08:52 PM
MidoriEK4's Avatar
Default Re: OK to run without thermostat? (NA CRX Si)
im a dumbass if you didnt have one coolant would run constantly. the only thing i could think of is that that engine would either take forever to reach operating temp or it would never reach that temp.
Old May 28, 2003 | 08:57 PM
1CiViC1's Avatar
reason why i was asking is because im overheating and have tried everything, but i just found out that my radiator fins are trashed, overhalf of the front fins are gone...so should i give the NO thermostat a try? or just stick to my "blasting on the heater full" until i can get a new radiator? (new radiator regardless of course) thanks
Old May 28, 2003 | 09:00 PM
MidoriEK4's Avatar
id do the blasting heater. ive never tried no thermostat. sounds too risky. up to you man.
Old May 28, 2003 | 09:01 PM
blah13's Avatar
Gone?! Holy ****, heh, go to a junker and grab one, $15-20 down here.
Old May 28, 2003 | 09:04 PM
EF8VTEC's Avatar
i was running without one for a while damn car never heats up to normal temp go buy one for $15.00 really easy to change 165F
Old May 28, 2003 | 09:14 PM
Proper's Avatar
If your car isn't up to operating temp it will do a lot more damamge than you'd think. When your car isn't at Operating temp the internals wear signifigantly faster and the oil will stay sludged for a longer period of time. Just save up and fix it right cuz you might have to fix more than just a radiator in the end.
Old May 28, 2003 | 09:44 PM
blackZC (W)
Guest
Posts: n/a
Default Re: OK to run without thermostat? (CamoHatch)
yeah if you got a JDM k20 swap then get a themostat...if not...meh
whatever, it will run cooler in the summer and your heat will suck in the winter.
i ran my 200k+ mile DX with no stat for years. and sludged oil did not own me.
Old May 28, 2003 | 10:00 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: OK to run without thermostat? (blackZC)
Camohatch is right.. if its not at proper engine temp, it will beat the **** out of the internals...
now as far as for a few days? sure.. but... keep in mind.. im not sure where you are, what kind of climate.. but once you get hot... and its half way.. thats it.. its not gunna cool down, thats what the thermostat does.. disapate heat.. just be careful.
Old May 29, 2003 | 01:35 AM
Stripped Honda's Avatar
99-0104
Default Re: OK to run without thermostat? (Built B16A)
PM'd you about a free radiator i have....
Old May 29, 2003 | 01:51 AM
1CiViC1's Avatar
Default Re: OK to run without thermostat? (Stripped Honda)
you got pm back, thanks man!!
Old May 29, 2003 | 08:01 PM
scn095's Avatar
I'm curious...
Why would not having a thermostat in the less-efficient-than-normal cooling system keep the engine too cool all the time? The radiator is doing less than 1/2 it's job (half the fins are gone), so won't removing the 'stat compensate?
(Or will it overcompensate?)
Old May 29, 2003 | 08:11 PM
boostedb16a3's Avatar
im glad this **** was brought up. i have a del sol vtec with a fmax turbo kit. my dumbass friend put some fucked up **** in my radiator and it has been running hot ever since. i changed the radiator to a 00 si unit...still hot...flushed coolant system out. close but no cigar. im a thnking about removing the stat'. i dont think a new modine or fluidyne radiator will do the trick. i heard alot about boostin cars getting hot. maybe a racing stat?
Old May 29, 2003 | 08:35 PM
pleasuretool's Avatar
Default Re: (boostedb16a3)
he put some sealant type junk in your radiator? the radiator might not be the problem, it could be clogging up something in your engine... you might wanna get it flushed...
also about no thermostat.. yeah it's bad to run w/o one... but i've heard of people gettinf like a piece of sheet metal, and driling a hole in the middle, then cutting it to size and putting it where the 'stat goes... that would restrict flow a little. but if a new one is only $15.. c'mon
Old May 29, 2003 | 08:59 PM
pokemon's Avatar
As long as you let your car warm up like you should let it anyway running without a stat is no problem, mainly in the summer I would run without one. In the winter it takes forever to warm up and then once you are driving it cools back down. If it is hot out and you take out your stat it will be fine. Might burn out the water pump faster but hey whatever.
Old May 30, 2003 | 12:56 AM
Built B16A's Avatar
Default Re: (pokemon)
for you guys that want to roll around wiht no thermo...
its not a good idea... i'll tell you why..
in the winter, you might get away wiht it.. but in all the manuals.. it says, let the fans kick in once.. for setting idle.. doing whatever.. now.. the cooling system...
if the fans kick in, its because the fluid is a certin temp. now take it back a step... why is the coolant hot? becuase the thermo opened, and cycled what was in the radiator, and still needed alittle more help.
now.. put it this way... once you reach propper coolant temp.. whats gunna cool it down? just fans? thats alot of strain to put on a fan.. then, what if you fan goes out around town? then your fucked...
manufacturs designed cooling systems for a reason.. the thermo is to disapate heat. the fan is more of a "oh ****" mode... does what the thermo can't handle.
if your rad. is new.. and new thermo, you prolly need to flush the block.. there's no other reason it could be. but hey, i could be wrong.
Old Dec 18, 2016 | 08:37 PM
Rob Cormican's Avatar
you guys are f****** idiots, of course you can run with no thermostat. It does not dissipate heat. All it does is open at a certain temperature 165 degrees to allow coolant to cool the engine. So. Unless you live in a area where it freezes you are good! Just hold it at high idl like 1800 to 2000rmp in the driveway for a few mins before you leave..then leave it in second wile driving threw the neighborhood. Let it rev to 2500- 3500rpm. As long as you dont fire it up cold and redline it..its fine.
Old Dec 18, 2016 | 09:16 PM
It Wasn't Me's Avatar
This thread is from 2003, genius.
Old Dec 24, 2016 | 04:09 PM
Ray Satomi's Avatar
The thermostat on my EF is stuck open right now, and I wouldn't recommend driving it like this. Takes forever to get to operating temp if it's warm out, and if it's under 50 it won't hold temp while driving. Destroys
Old Dec 24, 2016 | 07:35 PM
acmoc's Avatar
pros=none
cons= engine will not warm to operating temp which can cause damage since oil can't reach optimal op temp, neither can the engine.
bad mpg, look up "open loop"
thermostat closes at highway speed, so think how bad that will be for the motor to be revving cold all the time.
There are no pros, better to buy one
I go for aftermarket o.e. spec 180 degree. Can't be more than $20.00
If you want to save money, try to salvage as much clean coolant as possible, and refill with distilled water, only $.70
The o.e. honda one is 172 degrees but that's too cold. In my car, the needle drops at idle and raises back to operating temp when I start driving
linkdeezie
May 14, 2019 11:49 AM
EGcivic_95
31
Jan 29, 2011 06:09 PM
1991crx16
14
Jan 26, 2011 01:47 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
spock_rocker
Jun 6, 2005 03:32 PM
