headgasket thickness, please help ....
Old Jul 15, 2001 | 04:54 AM
Cyber ITR's Avatar
Default headgasket thickness, please help ....
im thinking to drop my b18c1 compression ratio to 9:1 , i just wondering whether u guys can tell me the thickness of a headgasket i should get .
thanks
Old Jul 15, 2001 | 10:01 AM
jinxproof99's Avatar
New User
Default Re: headgasket thickness, please help .... (VTEC_SiR)
you should call in line pro @ 703-644-1788. they're in virginia and they do mail order. they're headgasket drops a stock b18c1 to about 9.2:1. they know their **** regarding head gaskets. ask for stan or john lee. i run one and i love it.
Old Jul 15, 2001 | 12:09 PM
Jared's Avatar
Default Re: headgasket thickness, please help .... (jinxproof99)
I agree, I used to have an inline pro headgasket and it was the ****.
good luck,
Jared
Old Jul 15, 2001 | 03:06 PM
Mikex25's Avatar
New User
Default Re: headgasket thickness, please help .... (Jared)
How much is a inline pro head gasket for a b18c1?
Old Jul 15, 2001 | 03:21 PM
New User
Default Re: headgasket thickness, please help .... (Mikex25)
they are $299 plus shipping. they usually ship out within 3 days of order.
703-644-1788
Old Jul 15, 2001 | 11:53 PM
yellowbulbs's Avatar
New User
how much boost do u run to get that amount of hp?
i thought that stock map sensor only reads to 11 psi
what kind of fuel are u running?
how hard is it to install a head gasket
i am contemplating an inlinepro gasket
thaks
Old Jul 17, 2001 | 10:09 AM
New User
Default Re: headgasket thickness, please help .... (yellowbulbs)
you can run up to 22 lbs of boost on a stock block using the head gasket. this can net a stock gsr engine with no stand alone almost 400 hsp. we run 116-118 octane gas. you need a fmu, injectors, fuel pump, cam gears, and an afc. installing the head gasket is as easy as installing a stock one. call 703-644-1788 and ask for stan.
Old Jul 17, 2001 | 12:19 PM
FAST94GSR's Avatar
New User
What would my compression drop down to if have usdm type R pistons and a milled head?
(around 10.8:1-11:1)
In the future I want to go turbo with around 10lbs, then I'll do it right with the bottom end built.
Old Jul 17, 2001 | 12:51 PM
New User
Default Re: headgasket thickness, please help .... (FAST94GSR)
check your im.
duck22krazy
Nov 19, 2008 06:57 PM
civicminded3111
Oct 29, 2007 10:14 AM
silentdaredevil2
Nov 24, 2005 12:29 PM
c1hatch
Feb 18, 2002 08:45 AM
Charles B.
Oct 29, 2001 09:26 AM
