camber adjustionn needed for eibach springs?
hey u guys tink i would need a camber kit if i got eibach prokit(1.4drop) or eibach sportlines?(1.75 drop)? im really not trying 2 drop 100 for a dam camber kit, so yall tink camber would stay relatively the same with those kind of drops?
I have the Eibach Pro-kits on my Teg and my camber is a little bit more than spec on the passenger's side (spec is -1.31 degrees, I think and I have -1.36 degrees).
My toe, though, is right in the middle of the spec. That is the number I was more worried about than camber...
HTH.
HTH.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
For the Pro-Kits you won;t need a camber kit, just an alignment. For the Sportline's or anything else that low you'll need a camber kit. I've had my ProKits for 2 years and they are fine.
