going turbo....i need the little stuff now :(
im talking about all the little ****, like fittings and hoses and clamps and **** like that. is there a place that sells all of that in a packaage deal? id like to buy my own turbo and manifold and IC from diffrent kits. im just not gonna be happy with the WHOLE kit from someone like greedy or revhard.
or is a there a website where all this info im looking for might be? what about a website with turbo install instructions?
hey man i know the feeling... i made probably 10-12 trips to the hardware store down the street buying little clamps, hoses, fittings, zip ties etc etc. i found this pretty helpful, flamenco-T i think posted this (that's stan, right guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote"> Manifold to Turbo bolt size
Drag, Rev-Hard, Inline Pro - 10mm x 1.25 [30mm] ( length of the bolt)
Max-Rev - 3/8 x 24 fine thread
Turbo to Downpipe flange bolt size
T3 only 8mm x 1.25mm [20mm]
Oil return Flange bolt size
8mm x 1.25 [20mm]
35m Wastegate to manifold bolt size
8mm x 1.25 [20mm]
Stock Map Sensor Bolt
4mm x 0.7mm [15mm]
O2 sensor bung or bolt to plug it up
18mm x 1.50
Oil Return Parts list
Oil Drain Flange 1/2"
1/2" to -10AN adapter [981610erl]
2 of 45 deg or straight -10AN swivel seal hose ends [804610erl or 800110erl]
1' to 1.5' of -10 Performo flex lines [400100erl]
Steel -10 weld on bung [967110erl]
Oil feed line part list
1- male 1/8" BSPT to female 1/8" NPT adapter (aluminum)
1- 1/8" NPT Brass Tee adapter with one male out and two females.
1- 3.5' of -3AN lines with hose ends attach
1- straight 1/8" NPT to -3AN adapter
1- 90 deg 1/8" NPT to -3AN adapter
Top of stock fuel filter bolt size if you wanna run a SS lines to filter
12mm x 1.25
Greddy EGT probe bung thread size
1/8" NPT with 27 thread pitch
I'll add more as I remember...or if you have a suggestion, post it, and I'll add it to my list
stan
1 pack of the thin zip ties, and a bunch of those screw clamp things will help you out, you'll also need some T fittings for the vacuum lines.
dunno if that helped you out or not,
ryan
)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote"> Manifold to Turbo bolt size
8mm x 1.25 [20mm]
8mm x 1.25 [20mm]
4mm x 0.7mm [15mm]
18mm x 1.50
12mm x 1.25
stan
ryan
just search all post created by flamenco-t and you should find it.
edit here took me 30 sec to get it:
https://honda-tech.com/zerothread?id=373905
turbotime
Apr 2, 2006 08:44 AM
Xplicid01
Mar 22, 2004 06:17 AM
