Links for the EF crew.....
Old May 28, 2003 | 09:36 AM
DJ_SaNdOz's Avatar
Default Links for the EF crew.....
Just thought that I'd sahre some links that ya'll might appreciate....some have floated around before, and others you may not have seen.
http://nicotine.golden.net/D-Series/dseries.xls
http://www.knology.net/~jediklc/D.htm
http://users.ev1.net/~shinglin....html
https://honda-tech.com/zerothread?id=423680
http://www.carenthusiast.com/c...l.pdf
http://www.angelfire.com/dc/oregonimport
http://crx.honda-perf.org/math/index.html
http://www.geocities.com/motor....html
http://www.tunertoys.com/tech/HFManifoldD16.htm
http://www.geocities.com/kurtsi_on/page9.html
Old May 28, 2003 | 09:42 AM
DJ_SaNdOz's Avatar
Default Re: Links for the EF crew..... (DJ_SaNdOz)
here is also some info I compiled when I was thinking about swapping a B16 in my car....some info may be off a little, especially considering I don't have a B16, but this might help someone...
parts for b16:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Old May 28, 2003 | 12:14 PM
civbeater90's Avatar
great post
Old May 28, 2003 | 03:09 PM
DJ_SaNdOz's Avatar
Default Re: Links for the EF crew..... (civbeater90)
here is another that may help.....
https://honda-tech.com/zerothread?id=223361
wearedaughters
Jan 18, 2012 03:46 AM
MJ23FE
Other Make Vehicles
Nov 9, 2011 04:51 PM
si vtec ftw
May 1, 2008 10:39 AM
northemt88
Jan 6, 2008 08:41 PM
Fezzie
Jul 8, 2006 06:13 PM
