power steering makes groaning/grinding sound
Old May 28, 2003 | 07:22 AM
TypeR509's Avatar
New User
Default power steering makes groaning/grinding sound
lately, when i turn the wheel, towards full lock left or right, the steering or someting emits some sort of groaning sound, and i can feel the vibrations through the steering wheel and the accelerator pedal. Any thoughts on this??
Old May 28, 2003 | 07:25 AM
ITR764's Avatar
Default Re: power steering makes groaning/grinding sound (TypeR509)
check fluid level.
Old May 29, 2003 | 08:49 AM
TypeR509's Avatar
New User
Default Re: power steering makes groaning/grinding sound (ITR764)
fluid level is fine.
Old May 29, 2003 | 04:32 PM
Jeff R's Avatar
New User
is this what you are talking about?
https://honda-tech.com/zerothread?id=364346
Old May 29, 2003 | 05:25 PM
RickV's Avatar
Default Re: power steering makes groaning/grinding sound (rig74)
I had a similar issue in my R a few thousand k's after the 40,000km service (the major one I think you guys have 30,000 miles?). It turned out that the wrong transmission oil was used. My mechanic had used 10w30 as the service book said and as recommend by the guy he buys his Honda parts from. There had since been an update to the manual from Honda that said to use 75/85 and that the 10w30 can be used temporarily. But get this, when he called Honda they said that it should be 75/80 not 75/85 as the update said. He called a number of other dealers around town and they all gave different answers.
I would recommend flushing your transmission with 75/80 and see if the noise goes away - it did for me.
Old May 29, 2003 | 05:37 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR509 &raquo;</TD></TR><TR><TD CLASS="quote">lately, when i turn the wheel, towards full lock left or right, the steering or someting emits some sort of groaning sound, and i can feel the vibrations through the steering wheel and the accelerator pedal. Any thoughts on this??</TD></TR></TABLE>
Your belt is slipping or loose. Replace or tighten it.
Inextricabledrvr
Mar 18, 2009 07:56 PM
optikal_blitz
May 20, 2003 02:42 PM
SL!M
May 19, 2003 01:06 PM
Eskram
Jan 4, 2002 02:55 PM
blktyper2001
Oct 21, 2001 04:58 PM
