Steering Problems..ahh
Old May 14, 2003 | 11:28 AM
optikal_blitz's Avatar
Default Steering Problems..ahh
A few thoughts, questions, annoyances have to come to mind since having gotten my lude last september.
It's a 92 Si.
1) Steering is a little sluggish, and heavy. is this characteristic of preludes because of their weight?
2) Squeaking noise coming from (i'm assuming) the rack when steering at slow speeds..it's not too loud, but definitely noticable. Now that i think of it, more of a creaking noise..if it makes a difference to anyone.
3) When wheels are pointed straight away, the steering wheel is turned about 10-15 degrees to the left off-center.
Note::i had my power steering fluid checked/topped off..should i consider replacing completely?
Any help would be greatly appreciated..tips/suggestions on what to do about the offcenter steering wheel would be nice too.. sorry for the long post!
Old May 14, 2003 | 11:40 AM
Sephro's Avatar
Default Re: Steering Problems..ahh (NatakuBlitz)
did you make sure that your using Honda compatible ps fluid?
Regular ps fluid will damage the system
Old May 14, 2003 | 11:52 AM
i actually didnt do the fluid check..so i don't know what they used, if they had to even add any fluid.
Old May 15, 2003 | 03:43 AM
up before school.
Old May 15, 2003 | 03:46 AM
jakej's Avatar
Default Re: (NatakuBlitz)
low tire pressure makes the steering feel very heavy.... check that out.
Old May 15, 2003 | 10:27 AM
h2392si's Avatar
Default Re: (jakej)
try an alignment, that helped me out alot. Peace.
Old May 15, 2003 | 04:21 PM
thank you.
Old May 20, 2003 | 12:21 PM
bump for more thoughts.
Old May 20, 2003 | 02:22 PM
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">2) Squeaking noise coming from (i'm assuming) the rack when steering at slow speeds..it's not too loud, but definitely noticable</TD></TR></TABLE>
Does it squeak when the engine is not running, and you turn the steering wheel back and forth??
Old May 20, 2003 | 02:32 PM
yep
Old May 20, 2003 | 02:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">yep</TD></TR></TABLE>
Does it squeak when you push down on the corner of the front bumper(check both corners)? Up and down, up and down, Like bed springs in a whorehouse
noahs_ark
Honda Civic (2006 - 2015)
Sep 12, 2016 05:25 PM
robpreludevtec220
Feb 28, 2006 01:57 PM
sushib01
Jul 20, 2004 09:34 AM
Eskram
Jan 4, 2002 02:55 PM
blktyper2001
Oct 21, 2001 04:58 PM
