who runs cam gears on a boosted car
is it realy needed when runnung a supercharger to have adjustable cams gears. i have a set of AEM's but i put the stock ones back on till it's tunned. but do you need to adjust the cams when running a boosted aplication?
Before my power curve was up and down. After the curve was tuned with cam gears it was smooth. IMO if your gonna have your car tuned might as well have these to help overlapping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM »</TD></TR><TR><TD CLASS="quote">You don't need camgears unless your raising or lowering your compression since timing would be thrown off. </TD></TR></TABLE>
That's not entirely true. What kind of engine are you talking about? I have an ITR and lots of guys use cam gears to dial out the overlap. Some even use GSR cams because they have less overlap. Overlap is not related to compression ratio.
