I need some help with window replacement
Old May 28, 2003 | 03:18 AM
sacredc0w69's Avatar
Default I need some help with window replacement
Hey, I need to put in a newdriverside window and i aint paying 200 bux to get it professionally done... when i could just buy a window for 100 or less from the junkyard then just install it myself
however, i've never done anything like this so i was wondering if u guys could help me out and tell me when i need to do to take out the shards left from the oldwindowthat shattered, then put in thenew window...
i got a 90 accord lx 4dr
any help would be appreciated....
Old May 28, 2003 | 04:57 AM
Stew Pidasso's Avatar
Default Re: I need some help with window replacement (sacredc0w69)
A powerful shop vac will get the old glass out. When you take the door panel off, you will see the way the window bolts in. I believe it's only two bolts...
Old May 28, 2003 | 11:35 AM
yea i'm trying to take the door panel off but i can't
where the window unrolls is where its stuck
i'm not sure whether i can pull that right off or if i have to unbolt it somewhere...
can someone gimme a hand?
its not power windows its a manual roll down window
can i pul lthe handle right off? or what? i got the panel 99% off just that part is where i'm stuck
Old May 28, 2003 | 06:59 PM
anyone?
Old May 28, 2003 | 08:11 PM
StimpyBoy's Avatar
Default Re: (sacredc0w69)
The handle has a little ring piece near the base, you have to pull that ring off so you can remove the handle.
You're supposed to get a specific tool to pull it off. I got violent, pulled back the handle as far as I could, and used a long set of pliers. But I was furious, I'm not sure if I'd recommend this for you
Old May 28, 2003 | 08:35 PM
LoL, tat was my initial idea to pul lthe damn thing off
lol
just dont wanna break it and have to put it al bak 2gether (if possible)
so i remove that ring? how do i do that?
just kinda.....pull the ring off over the handle...?
Old May 28, 2003 | 09:41 PM
Spoonie Luv
Guest
Posts: n/a
haynes manual......always check their first
Old May 29, 2003 | 03:09 AM
its not in there
doesn't tell u how to remove door panels
tells u how to remove the dash but thats about it
the haynes manual is all exterior/engine work nothing about interior except dash removal
so does anyone know whether i can just pull the damn ring off over the handle? or wat?
Old May 29, 2003 | 07:15 AM
Heat's Avatar
My Haynes manual had information on how to remove my door panels (for a '99 Accord), take another look at yours.
Here is what the tool to remove your door handle looks like: http://www.midlock.nl/Adobe_en...s.pdf
you don't need the tool to remove it, it just makes it a lot easier. It's been 10+ years since I've removed a door handle, but as I remember it there is a ring shaped like a horseshoe that slips over the back of it, you have to pull that ring off.
Re-read the Haynes manual, it's gotta be in there.
Old May 29, 2003 | 10:34 AM
StimpyBoy's Avatar
Uhh, the Haynes manual for the 4th gens DEFINITELY has it in there. I know, I used it on my 92. Check again, it's in the section on door trim removal.
If you really want to know, I had the handle pointed upwards when I started. I pushed the door trim in as far as I could while pulling back on the handle. The ring runs around the base of the handle if I remember correctly. I took the pliers, and pulled the ring off (the ring is open at the bottom, you'll see, so it comes right off). I had to pull the handle pretty hard to get enough space to do it, maybe you'll have an easier time.
Get the longest, narrowest pliers you can, it'll make things easier.
Old May 29, 2003 | 05:27 PM
LoL okay thank u very much u guys
Old May 30, 2003 | 12:58 AM
Heat's Avatar
In your haynes manual for a 90 through 93 Accord, take a look at page 11-8. The picture in the center of the page, and it's description, will show you exactly what the clip looks like and how to remove it.
Old May 30, 2003 | 03:41 AM
ya i found it, its 11-6 though
thx alot
and how do i remove the old window thingy?
is it bolted or clipped in?
328ifun
Honda Insight & CR-Z Hybrid
Oct 22, 2014 04:16 PM
zroluv32
Oct 5, 2014 08:23 AM
acc0rdf22
Oct 8, 2009 12:17 PM
kimbynum
Jan 8, 2006 11:44 AM
blitz31
Jun 24, 2004 11:57 AM
