Need some info/advice/help... please
Old May 27, 2003 | 09:44 PM
Lude's Avatar
Default Need some info/advice/help... please
I have a '92 Prelude S, that I'm going to swap in an H22.
Now I'm wondering which way I should go, Stay OBD1 w/ an H22 from a 4th gen or go OBD2 with a 5th gen H22?
Also, what exactly do I need to do this swap. As far as I know it's pretty much a direct drop, I just need: engine, tranny, and ECU...
Any other advice...
Somebody, please tell me where to go.
Any information will be appreciated.
Old May 28, 2003 | 08:32 AM
prelittlelude's Avatar
Default Re: Need some info/advice/help... please (Lude)
for the most info do a search., i would def go with an h22 from a 4th gen, closed deck and obd1, you need ecu and engine, you could use you h23 tranny but i would suggest a h22 tranny .
Old May 28, 2003 | 09:26 AM
Elkins911's Avatar
Default Re: Need some info/advice/help... please (prelittlelude)
im not sure, but i think your going to need some new mounts also.
Old May 28, 2003 | 10:19 AM
CHK4TIX's Avatar
Default Re: Need some info/advice/help... please (Elkins911)
im pretty sure that the motor mounts are the same on all 4th gen
Old May 28, 2003 | 10:23 AM
Elkins911's Avatar
Default Re: Need some info/advice/help... please (CHK4TIX)
with SOHC and DOHC????
Old May 28, 2003 | 12:42 PM
Lude's Avatar
^^^I was wondering the same thing... F22 & H22... same mounts or not??
Old May 28, 2003 | 12:45 PM
Elkins911's Avatar
i dont think so.... i dont see the logic in that.
Old May 28, 2003 | 12:48 PM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think so.... i dont see the logic in that.</TD></TR></TABLE>
the mounts bolt to the block, and the blocks are virtually the same, so i would think the mounts would work, i could be wrong though
Old Jun 2, 2003 | 12:41 AM
Lude's Avatar
Bump.
Rymmer
Apr 10, 2010 03:19 PM
Bmxlambis
Aug 14, 2009 01:13 PM
o2 jockey
Oct 30, 2007 02:40 AM
91 lude si
Sep 6, 2004 03:02 PM
