Anything wrong with having the front lower than rear?
Old Jul 14, 2001 | 04:18 PM
BoM's Avatar
BoM
Default Anything wrong with having the front lower than rear?
is there anything wrong with having the front dropped like an inch or two lower then the rear? increase tire wear or what? or having prokits in the rear and sportlines in the front? what are the problems if any ?
Old Jul 14, 2001 | 10:32 PM
raene's Avatar
Default Re: Anything wrong with having the front lower than rear? (bommiE)
No, I can't think of any problems, except that the handling balance will probably be all messed up .
Old Jul 14, 2001 | 11:26 PM
5gen-hybrid's Avatar
New User
Default Re: Anything wrong with having the front lower than rear? (raeneshadow)
it also looks funny. there is this 6th gen civic coupe that is lower about 3 inches in the front and about 1.5 in the rear it looks funny and the biplane wing doesn't help it any either
Old Jul 15, 2001 | 11:08 AM
Stephen's Avatar
Default Re: Anything wrong with having the front lower than rear? (hybridxcivic)
If the front is too low you will have negative caster. That is not good.
Old Jul 15, 2001 | 04:11 PM
X2BOARD's Avatar
Default Re: Anything wrong with having the front lower than rear? (Stephen)
Having the front slightly lower than the rear (like I have) Will give you increased traction on the front wheels. However, if you have it too low, you will realize some problems cornering... the nose will dive while cornering and late braking.... you gotta use stiff shocks up front to compensate for this problem.
Old Jul 16, 2001 | 07:01 AM
92Si's Avatar
New User
Default Re: Anything wrong with having the front lower than rear? (X2BOARD)
I put front coilovers on and had difficulties with the rears. I left the fronts lowered until I could get on a lift and get the rears put on. The car drives alright, there is definitely a noticable "rake" from the back to front, but the car handles decently. For the track, I would think that a setup with a higher springrate in the rear would give the best results when launching.
Old Jul 16, 2001 | 11:05 AM
WAFFLES's Avatar
IT JUST LOOKS SILLY
dakid88
Suspension & Brakes
Jun 21, 2009 05:56 AM
urbach
Mar 10, 2009 04:08 PM
moores55
Honda Motorcycles
Jul 8, 2007 10:04 AM
ke98248
May 25, 2007 07:37 AM
tsouyporta
May 4, 2006 12:05 PM
