my windshield fluid won't dispense!
Old May 27, 2003 | 08:57 PM
9accordboy5's Avatar
Default my windshield fluid won't dispense!
no idea why it won't dispense when i trigger it to spray! was working 100% fine one day and next day it stopped working. any ideas?
Old May 27, 2003 | 09:16 PM
iam7head's Avatar
Default Re: my windshield fluid won't dispense! (9accordboy5)
have a friend tigger the sprayer while you listen closely to the water pump, see if the pump is working, if it does, go unpluge the nozzle thingie and have your friend trigger the water sprayer again. if the water came out from the hoses just fine the nozzle is clogged.
Old May 27, 2003 | 09:47 PM
jimbob thorton's Avatar
Default Re: my windshield fluid won't dispense! (iam7head)
refill it?
Old May 27, 2003 | 09:48 PM
eL's Avatar
eL
mine wont work because the line is cut where my hood meets my windshield... check the line
Old May 28, 2003 | 06:22 AM
lhhhbrown's Avatar
Default Re: (ReLL)
I have the same problem. Figured it would be one of the things mentioned. Good luck.
Old May 28, 2003 | 07:34 AM
93acclude's Avatar
Make sure there is not a kink in the line. The lines on 4th gens will get pinched where the line comes into the engine bay at the back corner of the hood. There is an "L" shaped hose that may have to be twisted down.
mynameizstitch
Aug 14, 2011 12:48 PM
si90rex
Sep 17, 2009 09:19 AM
Integra4lyfe069
13
Jul 14, 2009 07:28 PM
boostedeghatch
Jun 24, 2005 04:32 PM
EndlEEsss
Oct 2, 2002 12:33 PM
