Got oil in my spark plug and ignition wires
Spark plug tube o rings are shot. Easy fix. When you goto fix it though make sure you replace the valve cover gasket and o rings that mount under the bolts that hold the valve cover on too, if you dont you then you may spring a oil leak from one of those, since reusing gaskets is never a good idea.
But yeah, it's not a big deal for you, get the spark plug tube gaskets, should be 4 of them, place those. And if I were you, since I don't avoid spending money where it is needed, I'd gt some new NGK plugs and wires! OEM spec. Hope this helps
i got oil inmy spark plugs as well
theres been a post about this already with the exact same topic name
do a search
https://honda-tech.com/zerothread?id=508341
check ur valve's and pistons
do a search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReLL »</TD></TR><TR><TD CLASS="quote">nothing fixes this problem better than a swap
I like the way this guy thinks.
</TD></TR></TABLE>^
74celicagt
Feb 25, 2006 07:03 PM
