Installing Injen intake
Old May 27, 2003 | 08:52 PM
b_ricker's Avatar
Default Installing Injen intake
I pulled the black cap off of the opening that connects with a silicone hose directly to the engine and there is a rubber or silicon plug in there.......... do i leave it on or pop it out?
Old May 27, 2003 | 11:15 PM
DsITR's Avatar
Default Re: Installing Injen intake (b_ricker)
are you talking about the Vacuum hose on the Throttle Body??
(Injen writes some confusing instructions I know.)
If so, Injen supplies a cap to cap it off...you can put that one on, but it doesn't fit very well, so look for it to fall off in the near future.
Old May 28, 2003 | 07:13 AM
b_ricker's Avatar
Default Re: Installing Injen intake (dsludefosho)
It is this one right here? there seems to be some kind of plug in the hole going into the intake and this is my first install so don't want to get it wrong....... I circled it in the picture......
Thanks
Modified by b_ricker at 4:36 PM 5/28/2003
Modified by b_ricker at 8:34 PM 5/28/2003
Old May 28, 2003 | 11:28 AM
DsITR's Avatar
uhh, your picture isn't working for me?? did you host it on the net somewhere?
if you did, just right click on the image-copy the properties, and paste it in between the URL brackets.
like this
[URL/]IMAGEPROPERTIESHERE[/URL]
Old May 28, 2003 | 11:35 AM
b_ricker's Avatar
Hope it is working now if not go to http://www.injen.com/webpages/...0.jpg
and it is not circled any more but it is the bigger hose that goes right into the head.
Old May 28, 2003 | 11:52 AM
atlprelude01's Avatar
I have cai, lemme know how the short ram is
Old May 28, 2003 | 02:21 PM
DsITR's Avatar
Default Re: (atlprelude01)
I don't know what the hell the guy above me is talking about however..
Are you talking about the hose I have circled in the image below??
If so, that hose goes from the intake to the valve cover and I believe that is has something to do w/the PCV system.
don't quote me on this, but PCV stands for Positive Crankcase Velocity..
I believe It has something to do w/keeping the right amount of pressure for oil flow.
Someone Please correct me If I'm wrong.
Neither the Hole on the intake nor the valve cover should be capped...the hose should be connected as shown above.
Old May 28, 2003 | 07:44 PM
b_ricker's Avatar
Default Re: (dsludefosho)
Indeed that is the one I will unpluug the whole it seemed weird to me too....... thanks for your help........
Old May 29, 2003 | 06:05 AM
SMOOTH97LUDE's Avatar
dude get a crankcase fliter. it will look two times better. you can cap the stub on the your intake tube. if it is like my dac. use a bolt to cap it off.
crxaddikt
13
Jul 5, 2016 11:24 PM
95accord327
May 8, 2012 05:57 PM
Project22a
Oct 25, 2007 09:28 AM
m1ndless
Nov 29, 2006 12:12 PM
1bar
Mar 27, 2003 08:09 PM
