Clean dc2 headlights
Old May 27, 2003 | 07:43 PM
__37__'s Avatar
Default Clean dc2 headlights
i have a 95 and my headlights are looking a little yellow. anyone know if i can clean them up or if i have to buy a new set?
thanks
Old May 27, 2003 | 07:47 PM
Sportmode's Avatar
Default Re: Clean dc2 headlights (__37__)
http://www.team-integra.net/se...D=662
there ya go
Old May 27, 2003 | 08:13 PM
__37__'s Avatar
Default Re: Clean dc2 headlights (Sportmode)
thanks. i have that stuff already. it works real well on my exhaust. never thought to try it on my headlights. thanks
Old May 27, 2003 | 08:21 PM
B U N M A N G O's Avatar
rubbing compound works if metal polish doesn't- here's my thread w/ pics from when I cleaned my aunt's Civic https://honda-tech.com/zerothread?id=504832
first use rubbing compound, then follow up with metal polish
Old May 27, 2003 | 08:55 PM
95integrags-r's Avatar
Default Re: Clean dc2 headlights (bunmango)
hope this helps
https://honda-tech.com/zerothread?id=290368
I never ended up getting around to doing n e of those for a fear of scratching and ruining my headlights...but I think I will try out that nevr-dull stuff and see how that works...
Old May 28, 2003 | 01:10 PM
__37__'s Avatar
Default Re: Clean dc2 headlights (95integrags-r)
quick update: i tried both neverdull and toothpaste and the toothpaste seemed to work better. i just put it on a wax applicator pad and rubbed away. only took about 10 minutes and $0.30 worth of toothpaste. this is a must try for everyone that doesnt like their yellow headlights.
toothpaste
Old May 28, 2003 | 01:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by __37__ &raquo;</TD></TR><TR><TD CLASS="quote">quick update: i tried both neverdull and toothpaste and the toothpaste seemed to work better. i just put it on a wax applicator pad and rubbed away. only took about 10 minutes and $0.30 worth of toothpaste. this is a must try for everyone that doesnt like their yellow headlights.
toothpaste </TD></TR></TABLE>
hahah yea I forgot to mention the obvious- toothpaste. Good to know it worked out for you
Old May 28, 2003 | 04:31 PM
Trac226's Avatar
I just use a plastic polisher and cleaner compound. Works great...you can use it for CD's too.
Old May 28, 2003 | 06:17 PM
integral94's Avatar
i hear coca cola works. just leave it on for a couple minutes and then wipe it off. the stuff is acidic, so be careful around paint. (just apply coke to a cloth and rub it on the lenses maybe)
Old May 28, 2003 | 06:28 PM
tC_Dragon's Avatar
Default Re: (integral94)
i've done the rubbing compound n metal polish method several times and was happy with the results every time.... i do it to my own car's headlamps bout once a year or so.
Old May 28, 2003 | 06:46 PM
E-Rok's Avatar
EPIC TUNING
Default Re: (pdcdragon)
rubbiung compound works GREAT. my headlights on my 94 were cloudy and yellow, I used some rubbing compound and now they as clear as my boys 99 GSR
Old May 28, 2003 | 07:15 PM
mr.beeks's Avatar
another satisfied customer
and please dont be sketical with this method...
Old May 28, 2003 | 08:15 PM
ScaleExtric's Avatar
Default Re: Clean dc2 headlights (N T R Z R)
sand them down..with ruff grit and work your way up to like 1500 grit..then buff them out with some rubbing compound on a electric buffer...they'll look better then new
Domexxx
Lighting
May 21, 2008 12:33 PM
duyfash0
Oct 16, 2007 01:16 PM
D-rush08
Oct 30, 2006 08:44 PM
Civic4less
15
Nov 7, 2004 02:13 PM
streakz
Jun 13, 2003 02:26 PM
