Difference between F22 Vtech and Non-Vtech
Old Jul 14, 2001 | 02:36 PM
Rob03Pro5's Avatar
Default Difference between F22 Vtech and Non-Vtech
A buddy of mine has a '97 Accord Non-Vtech. He wants to swap heads with an Accord Vtech.. how hard would the process be? Any fuel modifications? Swap out the ECUs? What about manifolds? How hard would it be if he has the head and the manifolds? Any help would be appreciated.
Old Jul 14, 2001 | 05:45 PM
Conechaser's Avatar
Default Re: Difference between F22 Vtech and Non-Vtech (Rob92SC)
uh, its vtec, not Vtech.
as far as your question goes, i dunno...doesn't seem worth it to me though.
Old Jul 14, 2001 | 06:18 PM
SOHCArchangel's Avatar
Default Re: Difference between F22 Vtech and Non-Vtech (94Accord)
either do a h22 swap, or boost the living **** outta it, swapping heads too much trouble...
Old Jul 14, 2001 | 07:11 PM
Rob03Pro5's Avatar
Default Re: Difference between F22 Vtech and Non-Vtech (SOHCkordVTEC)
94Accord,
Hey man, thanks for that helpful response. I thank you for clearifying that a non-Vtec head has no Vtec technology. I was just going nuts trying to figure it out by myself. You definitely seem to be an ASSet to this board! I'm looking forward to any more wise(***) replies you might have.
Old Jul 14, 2001 | 08:06 PM
Conechaser's Avatar
uh, i never said that it wouldn't help, i guess you just ASSumed that. But the effort, time, money, it would cost just isn't worth it for the 15 or so hp difference. Might as well swap the whole motor w/ a H22 or turbo the non-vtec motor, like suggested above.
Old Jul 17, 2001 | 09:27 AM
Dropped's Avatar
New User
Hey man the F22 is an 2.2L SOHC. I had an 1992 Lude S and I got rid of it b/c the mods out there for it aint that great. As for your question I recommend there is really no vtec improvment for that engine. All that you really can do to that is is SPRAY and mill the heads and run Air Intake and Exhaust/headers. I didnt go that far with mine. I say to much $$$ outta my pocket for such an small motor and red lining at 6K kinda suked ***! So i sold it and got DOHC, and now I feel much confident and love the torque and response of my Peppy integra!
So I would recommend staying away from the F22 motor is you plan on moding.. Unless you really want to sped you pocket book in a BIG way!
Good Luck!
Old Jul 17, 2001 | 10:12 AM
Default Re: Difference between F22 Vtech and Non-Vtech (Dropped)
cam, ecu reprog, springs, boost, all u needa know
Old Jul 19, 2001 | 11:17 AM
NineTwoAccord's Avatar
New User
damn, yal can be some dicks.
yes there is potential in the f22, but it costs allot of money. a vtec head, if you got it to work properly would add some hp. but probably only by about 10. if you can get it to work and you get the parts cheap and sounds good to me, but it would be allot of work. you would need the vtec electronic components also, not just the head.
a fellow honda-tech member screamer7 has a built up f22 running 15's. it probably has cost him more than a h22 motor would, but it is definately possible to take a f22 into 15s and beyond. i've seen a 13 second built and turbo'd f22 on purehonda.
Old Jul 19, 2001 | 11:18 AM
New User
Default Re: Difference between F22 Vtech and Non-Vtech (NineTwoAccord)
no you wouldnt need to swap manifolds, but yes to the ecu and vtec solenoid.
Old Jul 19, 2001 | 01:50 PM
Conechaser's Avatar
uh, my car should run mid->high 15s and all i have is an AEM CAI. What all does he have done to run 15s?
Old Jul 19, 2001 | 01:54 PM
screamer7's Avatar
New User
15.3 on gtech I/H/E 11.2 lbs flywheel, clush speaciaty clush w/6 puck disk. "with the full build head dont no yet maybe mid to low 14s."
Old Jul 19, 2001 | 02:29 PM
Conechaser's Avatar
Default Re: Difference between F22 Vtech and Non-Vtech (screamer7)
any times from a track?
Old Jul 19, 2001 | 10:15 PM
screamer7's Avatar
New User
not yet when i do ill post time slip right now only gtech
khronicboy420
Dec 21, 2008 07:47 PM
streatbeetz23
Jun 14, 2006 07:03 AM
myrevenge
Apr 26, 2006 01:57 AM
95luda
Jul 26, 2004 06:30 AM
nuro
Mar 27, 2003 07:23 AM
