b18 axle problems in crx?? need help!!!
i bought a crx with a b18a swap into to it and the passenger side mount was welded the wrong way so now the engine sits forward and the axle sits at a slant ,i heard that by buying the hasport kit this problem is solved but i am on a budget ,do i have any other options then to spend 400$ on a kit ,please heeeeeeeeeeeeeeeeellllllllllllllllllpppppppppppppp pp me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickyt60 »</TD></TR><TR><TD CLASS="quote">i bought a crx with a b18a swap into to it and the passenger side mount was welded the wrong way so now the engine sits forward and the axle sits at a slant</TD></TR></TABLE>
How did they "mount" the engine? You might need to return the car back to factory specs withte mounts brackets and such. A B series mount kit is the only way to go: HASport, HCP, Place, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickyt60 »</TD></TR><TR><TD CLASS="quote">i heard that by buying the hasport kit this problem is solved but i am on a budget ,do i have any other options then to spend 400$ on a kit ,please heeeeeeeeeeeeeeeeellllllllllllllllllpppppppppppppp pp me
bump
</TD></TR></TABLE>bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
How did they "mount" the engine? You might need to return the car back to factory specs withte mounts brackets and such. A B series mount kit is the only way to go: HASport, HCP, Place, etc.</TD></TR></TABLE>
Chris said it all.
Sorry man. I would definitely return **** back to stock and go with HASPort, HCP or Place racing mounts.
Chris said it all.
smapty
Aug 29, 2005 10:31 AM
Rocks
Jun 30, 2004 07:47 AM
