Si head on Hf block
Old May 27, 2003 | 03:34 PM
crxracr's Avatar
Default Si head on Hf block
will a 1.6L Si head mount on a 1.5L Hf block?
Old May 27, 2003 | 04:46 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: Si head on Hf block (crxracr)
it might mount on there but the hf pistons have only 2 valve reliefs (thats what i have heard...ive never had the head off one) so the pistons will more than likely hit the valves.
so youd have to change the pistons...just save for a d16a6 swap, you can get a complete swap for somewhere around $300 (dont quote me on that though)
Old May 27, 2003 | 07:45 PM
AudioXtremes's Avatar
Default Re: Si head on Hf block (fastcrxsi90)
I have done it before. they don't hit but its dangerous.
Old May 27, 2003 | 08:03 PM
rjardy's Avatar
WAIT a minute, are you talking about puting a b series head on a d series block?
If so, it wont work.
Rob
Old May 27, 2003 | 09:11 PM
RCautoworks's Avatar
Default Re: Si head on Hf block (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">WAIT a minute, are you talking about puting a b series head on a d series block?
Rob</TD></TR></TABLE>
No hes talking about the 1.6 si d16, not the 1.6 si b16.
Old May 27, 2003 | 10:11 PM
EFRue57's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">it might mount on there but the hf pistons have only 2 valve reliefs (thats what i have heard...ive never had the head off one) so the pistons will more than likely hit the valves.
so youd have to change the pistons...just save for a d16a6 swap, you can get a complete swap for somewhere around $300 (dont quote me on that though)</TD></TR></TABLE>
My brother has the swap on his CRX and he milled his head 30 thousandths and it runs fine with no problems. When we were swapping the heads we thought the same thing about the valve reliefs and were even more worried because we milled the head but after all was said and done it ran awesome.
Old May 28, 2003 | 01:35 AM
91civicDXdude's Avatar
i dont doubt that, one of my friends had an 89 CRX DX and we swapped a sohc zc head onto the d15b2 block, that little sucker SCREAMED
Old May 28, 2003 | 10:24 AM
streetlegal gocart's Avatar
Default Re: (91civicDXdude)
da6teg, did you swap the pistons?
Will a stock d16a6 or d15b7 work onto the stock hf block?
Old May 28, 2003 | 03:17 PM
crxracr's Avatar
Default Re: (Doctor Zagato)
so the SOHC ZC head will fit on the d15 block also? I assume that the D15B2 and the D15B6 are pretty much the same block and the only difference between the engines is the heads? right?
DAtegLs
Classic Hondas
Mar 31, 2008 03:52 PM
RYan McG.
22
Jan 12, 2007 12:08 PM
Teal95Coupe
Jun 18, 2004 07:57 AM
Dorifto13B-T
Aug 9, 2003 10:55 PM
rabidpanda
Mar 23, 2003 02:25 PM
