O2 sensors questions.....
Old May 27, 2003 | 01:55 PM
buzz_worthy321's Avatar
Default O2 sensors questions.....
I have a 91 hatch with sir swap (b16a) and i was wondering if i need the first o2 sensor hooked up up .. i know i need the 2nd for vtec to work....
Old May 27, 2003 | 01:57 PM
Urban Business
Guest
Posts: n/a
Default Re: O2 sensors questions..... (buzz_worthy321)
yes otherwise you'll throw codes and the thign will run like crap
Old May 27, 2003 | 01:59 PM
REDBARON's Avatar
Default Re: O2 sensors questions..... (limoZeen)
You need to hook both of them up. Make sure you connect the right one at the right pin on the ECU.
Old May 27, 2003 | 02:03 PM
slowpokesi's Avatar
you can run without any o2 sensors and your vtec will still work, vtec doesnt rely on the o2 sensor, so whoever told u that was a fucktard.
as far as your car, if you dont mind it running shitty then sure, cheap out and only run one o2 sensor,
if you want your car to run correctly then you need 2 o2 sensors, or an ecu that will cancel out the 2nd o2 sensor *(zdyne , or mugen chip)
Old May 27, 2003 | 03:37 PM
Default Re: O2 sensors questions..... (slowpokesi)
I have been looking for a chip but the only place i know that just sells the chip is hyperduck tuning... you know anywhere that will just send me the chip....
ken2830
Feb 1, 2008 12:09 AM
crx_si-r
Aug 14, 2007 06:34 AM
EF8IGHT
Nov 6, 2005 09:08 PM
BseriesHatch
Jul 18, 2004 05:08 PM
maximedx
12
Jun 1, 2002 10:53 PM
