Greddy oil filter block adapter.
Old May 27, 2003 | 11:48 AM
Prelude Vtec 23's Avatar
Default Greddy oil filter block adapter.
Has anyone used this? Just wondering what you guys think about it, any problems w/ it, was it worth getting?
Old May 27, 2003 | 11:54 AM
NXSpoon's Avatar
Default Re: Greddy oil filter block adapter. (Prelude Vtec 23)
Just Im'ed you.
Old May 27, 2003 | 03:22 PM
Default Re: Greddy oil filter block adapter. (NXSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXSpoon &raquo;</TD></TR><TR><TD CLASS="quote">Just Im'ed you. </TD></TR></TABLE>
Thanks for the info......nobody else has this??
Old May 27, 2003 | 07:12 PM
Final bump............come on guys is this not popular for people to use? What it does is goes in between the oil filter and the block. Then you can easily attach the connections for the oil pressure gauges and temp gauges. Just wanted to know if people are using this and/or had any problems w/ it. And if it gave accurate readings.
Old May 27, 2003 | 07:32 PM
Hayasa15's Avatar
can you use it as an oil feed?
Old May 27, 2003 | 09:50 PM
NXSpoon's Avatar
Default Re: Greddy oil filter block adapter. (Hayasa15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">can you use it as an oil feed?</TD></TR></TABLE>
There are 2 small points for sensor hookup as well as a larger one that I THINK some of the turbos guys are using for an oil feed. However, I have only heard this in theory, I do not know if actually works.
Old May 30, 2003 | 06:45 PM
Hayasa15's Avatar
anybody else know if the sandwich adapters can be used for oil feed?
Old May 30, 2003 | 07:03 PM
B18Flip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">anybody else know if the sandwich adapters can be used for oil feed?</TD></TR></TABLE>
yes. ACautotechnic, greddy and golden eagle make them. I'm 100% sure that the acauto and GE can be used for oilfeed but not totally sure about the greddy. I think ladysman is selling a GE in the classifieds
Old May 30, 2003 | 07:12 PM
igo4bmx's Avatar
i just bought an ac autotechnic oil plate.,.
it has four 1/8 npt holes ...
i used two of the openings (oil feed for turbo and oil pressure sensor) and the rest were plugged in...
ActiveAero
Jan 24, 2005 05:34 AM
crxzcracer
Jan 4, 2005 11:56 AM
jeremy.
Sep 27, 2003 04:15 PM
BlackB18CTeg
May 14, 2003 02:45 PM
