integra brakes on my90 civic hatch help?
Old May 27, 2003 | 10:56 AM
cdn90civicsi's Avatar
Default integra brakes on my90 civic hatch help?
iv got a 1990 civic hatch i want to put front and rear brakes off of a 90-91 integra . is this possible witch parts do i need off the teg? do i need the master cylnder and porp. valve?????
any help would be awsome
thanx
Old May 27, 2003 | 11:34 AM
raene's Avatar
Default Re: integra brakes on my90 civic hatch help? (cdn90civicsi)
Searching 0wnz J00...
https://honda-tech.com/zerothread?id=491656
https://honda-tech.com/zerothread?id=387041
https://honda-tech.com/zerothread?id=274902
https://honda-tech.com/zerothread?id=242167
https://honda-tech.com/zerothread?id=182920
HTH
Hmmmmmmmm.... now I've gotta hit up the junkyard soon, I need to replace my rotors and pads anyway....
Old May 27, 2003 | 11:43 AM
raene's Avatar
Default Re: integra brakes on my90 civic hatch help? (raene)
Just from checking some of the links, it seems that the Integra front brake setup will not clear the stock CRX Si wheels - can anyone verify this for me before I consider wasting money? Thank you in advance
Old May 27, 2003 | 12:56 PM
REDBARON's Avatar
Yes they will clear.
Old May 27, 2003 | 01:27 PM
MAD SCIENTIST's Avatar
Default Re: integra brakes on my90 civic hatch help? (REDBARON)
for the rear just take the trailling arm and all the braking components that attach to it hoses cables calipers.u do not need the lower control arm
Old Jun 13, 2003 | 11:58 PM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">Yes they will clear. </TD></TR></TABLE>
j00 lied They do not clear '88-'89 wheels... evidently the '90-'91 wheels must have a *slightly* smaller internal clearance, maybe 1mm more... seriously. I can almost bolt the wheels on, but they do not clear the Integra calipers. What a poopy night
For comparison purposes:
My old KVR x-drilled rotors, KVR pads (rotors have hairline cracks all 'round):
New Integra brakes, circled areas are slightly raised so contact is made with the wheel inside:
I'm going to shave down the contact points on the calipers. I REALLY can't afford to get new wheels, especially after dishing out for the brakes!
Old Jun 14, 2003 | 10:45 AM
raene's Avatar
No one has any info?
Man, I'm breaking new ground here... d'oh.
Old Jun 14, 2003 | 11:18 AM
raene's Avatar
After having another look at it, it doesn't look like the circled portions are actually what's contacting the wheels - it looks like the frontmost portion of the caliper, the part that extends out the wheelwell towards the lugs, is contacting the inside of the wheel, the facing surface. So I'm going to pick up a couple of wheel spacers and see if that fixes it
Old Jun 14, 2003 | 02:31 PM
bryant's Avatar
spacers should fix the problem. But I would suggest some Extended studs if your going to do that.
Old Jun 14, 2003 | 02:49 PM
raene's Avatar
Default Re: integra brakes on my90 civic hatch help? (Bryant)
Yeah, I'm going to pick some up; there's only about half the thread going into the lugs now
Spacers worked great However, steering effort is higher now
Old Jul 20, 2005 | 02:57 PM
89efeight's Avatar
Old Jul 20, 2005 | 03:21 PM
Keith P's Avatar
Default Re: integra brakes on my90 civic hatch help? (89EFeight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89EFeight &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Holy old post bump! Couldn't he grind a little off of the caliper to get it to fit?
eknsi
Oct 12, 2010 07:26 PM
JDMJAYDC2
Jun 15, 2007 05:13 AM
Boosted_CRX_507
Jun 11, 2007 06:04 PM
uh huh
Oct 22, 2006 06:34 PM
hedturner3816
Sep 15, 2004 04:12 PM
