open end lugs for extended studs
Old May 27, 2003 | 09:11 AM
MugenGTR's Avatar
Default open end lugs for extended studs
i got myself some skunk2 extended lug studs for cheap but haven't had a chance to put them on since i don't have any open end lugs. what would you guys recommend? i know a lot of people use Kyokugen but i also heard they were pretty shitty. the skunk2 lugs are supposidly crappy too i think. any suggestions?
also do i really NEED to weld the studs? i know i won't be making any more then 180whp..
Old May 27, 2003 | 09:14 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: open end lugs for extended studs (MugenGTR)
I use Skunk2 nuts....
Old May 27, 2003 | 09:33 AM
turbochic's Avatar
ask exospeedAMcrx, he could probably help you a lot
Old May 27, 2003 | 11:37 AM
sparkz's Avatar
Default Re: open end lugs for extended studs (fmaxturbochic)
you can use the skunk2 lugs or goto pep boys and buy the regular open end style lugs. theyre like $14 for all 16
Old May 27, 2003 | 04:10 PM
rolow's Avatar
Default Re: open end lugs for extended studs (sparkz)
These look nice
http://www.Honda-tech.com/zerothread?id=441547
I have the axes but run a cheap old Honda open end ones most off the time!
O and the skunk2 studs suck yes you have to weld them in the knurl is to small and if you don't weld them they will spin in the hub. Also if you do use them make sure you chase the threads with a die because the threads on most of them are bad.
I would save the headache and get a set of ARP $30 for 8
Old May 27, 2003 | 06:42 PM
MugenGTR's Avatar
Default Re: open end lugs for extended studs (rolow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolow &raquo;</TD></TR><TR><TD CLASS="quote">
I would save the headache and get a set of ARP $30 for 8 </TD></TR></TABLE>
i would too, but they have been on back order at summit for awhile now, if you know of any other place that has them i'll definitely get them!
Old May 27, 2003 | 06:52 PM
MugenGTR's Avatar
i don't normally buy cheap name piece of shiet parts but these lugs look pretty impressive. they're hayame, i can get them for $50 for all four wheels...
Old May 27, 2003 | 10:04 PM
tony1's Avatar
I agree, skunk 2 studs are shitty. The threads will decide to seize up out of nowhere after a while. I'd get some arp's, whatever knurl size they have that's a 12 x 1.5 thread. Drill the hub for whatever knurl size you bought and then tack weld them in a few spots on each stud. That's what i would do anyway...
Old May 27, 2003 | 11:57 PM
turbospool's Avatar
Default Re: open end lugs for extended studs (tony1)
Skunk2 lug nuts are ok, the studs suck. I use ARP extended studs (summitracing just got a shipment) and skunk2 lug nuts. very light.
Old May 28, 2003 | 05:44 AM
ScrapinSi's Avatar
Default Re: open end lugs for extended studs (turbospool)
I've heard that you can use Chevy Studs too, and that they are like an 1 to 1 1/2" longer than stock... Anybody heard of this?
Old May 28, 2003 | 05:52 AM
compact-tuner's Avatar
i use the arp 12mmx1.50 pitch x2.5long studs pressed into the factory hub.i also use a 3/4"shank weld lug nut.seems to work great!
just my 2cents
compact-tuner
Old May 28, 2003 | 06:51 AM
rolow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenGTR &raquo;</TD></TR><TR><TD CLASS="quote">
i would too, but they have been on back order at summit for awhile now, if you know of any other place that has them i'll definitely get them!</TD></TR></TABLE>
Inlinefur.com has them listed in the whats new section.
I know EF8_Fan has some sets (just make sure he does not sell you mine)
Here is his profile
https://honda-tech.com/zerouser...28577
BAZ
15
Oct 1, 2006 04:54 PM
FredoSP
Sep 21, 2005 10:21 AM
DEL HATCH
Jun 20, 2005 06:04 PM
slixxracing
Feb 6, 2004 08:52 PM
paulzy
Jun 10, 2002 12:21 AM
