Torque Spec for ITR front caliper bolts
Old May 27, 2003 | 12:34 AM
ucb's Avatar
ucb
Default Torque Spec for ITR front caliper bolts
Hi,
Im swapping out the front pads on my accord v6, havnt dished out for the helms yet, so if you can, look up the torque specs for the ITR caliper.
Thanks
Old May 27, 2003 | 05:10 AM
EleanoR's Avatar
Default Re: Torque Spec for ITR front caliper bolts (UCBGSR)
While i don't have the Helms in front of me if memory serves correctly the torque spec on the caliper bolt is 23 fl lbs and the caliper mounting bolt (17mm bolt) is 80 fl lbs. Anyone feel free to correct me if i am slightly off on the 23 flt lbs but the caliper mounting i know is 80
Old May 27, 2003 | 05:24 AM
pyromaster's Avatar
Default Re: Torque Spec for ITR front caliper bolts (EleanoR)
the 14mm bolt is 36 ft lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">While i don't have the Helms in front of me if memory serves correctly the torque spec on the caliper bolt is 23 fl lbs and the caliper mounting bolt (17mm bolt) is 80 fl lbs. Anyone feel free to correct me if i am slightly off on the 23 flt lbs but the caliper mounting i know is 80</TD></TR></TABLE>
Old May 27, 2003 | 05:27 AM
BudMan's Avatar
close...the back is 24, but the front is 36.
Old May 27, 2003 | 12:41 PM
ucb's Avatar
ucb
Default Re: Torque Spec for ITR front caliper bolts (BudMan)
thanks guys
Old May 27, 2003 | 12:56 PM
EleanoR's Avatar
hey i was 13 flt lbs off what the heck
ray.riddler92
Jul 27, 2011 05:07 PM
onwisconsin81
Apr 5, 2010 01:25 AM
infamousALLMTR
Jun 16, 2003 07:33 AM
1hotintegra
Mar 18, 2003 08:41 AM
