CAI to charge pipe?
just wondering if it is possible to convert a AEM CAI for a LS into a charge pipe for a turbo? has anyone ever done/seen one done? just wondering if it is possible?
i'm using my cai as part of my chage piping. you will have to disconnect the breather tube from the valve cover and hoseclamp a bolt into it to plug it and then put a breather filter on the valve cover or reroute it to your intake before the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 »</TD></TR><TR><TD CLASS="quote">i'm using my cai as part of my chage piping. you will have to disconnect the breather tube from the valve cover and hoseclamp a bolt into it to plug it and then put a breather filter on the valve cover or reroute it to your intake before the turbo.</TD></TR></TABLE>
Umm what happens if you don't disconnect the breather tube? Cause I'm using a AEM cai right now but I didn't do that. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_sir »</TD></TR><TR><TD CLASS="quote">
Umm what happens if you don't disconnect the breather tube? Cause I'm using a AEM cai right now but I didn't do that. Thanks.</TD></TR></TABLE>
You are sending boost pressure into your engines crankcase. Where it goes from there I dunno, could shoot out your dipstick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">isnt the pipe aluminum? it will be hard to weld a blow off valve onto there right?</TD></TR></TABLE>
then you can put your bov before the intercooler
shouldn't be, u just need to get an aluminum flange and have a farily competent welder
mike
mike
i welded my bov to my steel charge piping between the end of my cai and my fmic. it's mounted in the front bumpter where the filter used to be. it's a 1g dsm bov. i found a small k&n filter to mount on it so it doesn't suck up crap while cruising in vacuum open.
WOuldnt it be a better idea to get a generic CAI off Ebay for $40 and use that? AEM CAI's are damn expensive, its better to cut up a cheap one and save or sell the AEM.
My thoughts
My thoughts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">WOuldnt it be a better idea to get a generic CAI off Ebay for $40 and use that? AEM CAI's are damn expensive, its better to cut up a cheap one and save or sell the AEM.
My thoughts
If you're going from NA to FI and already have an AEM CAI, why waste another $40? Use what you have.
My thoughts
</TD></TR></TABLE>If you're going from NA to FI and already have an AEM CAI, why waste another $40? Use what you have.
