Installed my snap in kit.
Old May 26, 2003 | 10:29 PM
IGGY's Avatar
Default Installed my snap in kit.
After purchasing and installing my Sparco harnesses (https://honda-tech.com/zerothread?id=496593), I was a bit bothered by my lap-belts. I had managed to keep my stock seatbelt in original working order, but I was constantly having problems finding places to put my lap-belts when they were not in use. As a result, I purchased a clip in kit. I followed the directions from S& M Racing which proved to be very helpful.
I followed all the steps with the following exceptions:
1.I removed the entire exhaust system. This really helped because it was easier for me to work on the car from under, and I was able to clean my exhaust and weigh it. (FYI the JDM spec Mugen twin loop for the DC2 weighs as follows: B-pipe = 18.2lbs / Axel back = 19.4lbs)
2.I used a 2 ½” washer in front and a backing plate in rear (see illustration below).
3.I did not place my left eyebolt in the stock mounting bracket. I drilled an extra hole in the floor behind the seat and placed it there. I did this because I was unhappy with the fitment of the eyebolt in the sock location. The stock seatbelt could not swivel like it once did with the eye bolt in place. I followed the same directions as with the other, and double backed the eyebolt with an extra nut.
4.Since I had so much thread left I figured I would add an additional line of safety. After everything was installed I dilled a hole through the bolts close to the nut and interested a pin. If under any circumstances a bolt came loose, it would not wiggle out completely and still be able to serve its purpose.
Here are the pics:
Here is me jacking up the car with a fork lift at work:
Ground clearance of the bottom eye bolt:
Clearance with resonator and second eye bolt:
Heat shield cut up:
Tools of the trade:
This tool is a peice of ****:
This is how the belts clip in and out:
Snap in's come with a saftey hole:
The snap in itself:
I tried to get a good pic of the hidden washers under the carpet, but they did not come out good:
Finished product:
I installed roll bar padding as I was advised to do so:
MARTIN giving a we-todd solute:
Old May 26, 2003 | 10:39 PM
B2FiNiTY's Avatar
Default Re: Installed my snap in kit. (IGGY)
lol @ the forklift. How much did the padding run you?
Edit: https://honda-tech.com/zerothread?id=496593 for pics of the harness
Old May 26, 2003 | 10:48 PM
Boost Ambassador's Avatar
Default Re: Installed my snap in kit. (B2FiNiTY)
[QUOTE=B2FiNiTY]lol @ the forklift. How much did the padding run you?
NIce pixs!
Old May 26, 2003 | 11:20 PM
IGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">lol @ the forklift. How much did the padding run you?
I got padding a little expensive $6 for 3 feet.
Old May 27, 2003 | 12:17 AM
NA gs-R 05 C
Guest
Posts: n/a
haha, forklift saved u alot of time huh.
Old May 27, 2003 | 03:42 PM
IGGY's Avatar
Default Re: Installed my snap in kit. (LS60-1)
No one saw something interesting in post?
Old May 27, 2003 | 03:58 PM
P1mpSlap's Avatar
LOL, a gator grip. I have one of those. I use it to gank road signs and **** in restuarants.
Old May 27, 2003 | 05:48 PM
Bob#455's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">No one saw something interesting in post?</TD></TR></TABLE>
I find it interesting that:
A) You still have heatshields installed with your Mugen exhaust, and
B) You couldn't find a place to put the lap belts when mine have been sitting on either side of my seat with no problems for the last year
Old May 27, 2003 | 05:51 PM
.RJ's Avatar
.RJ
nice work - clean install
Old May 27, 2003 | 06:14 PM
IGGY's Avatar
Default Re: Installed my snap in kit. (Bob#455)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob#455 &raquo;</TD></TR><TR><TD CLASS="quote">
B) You couldn't find a place to put the lap belts when mine have been sitting on either side of my seat with no problems for the last year </TD></TR></TABLE>
Ha,ha. I would have thought you would have noticed it Bob.
I guess no one reads the posts, just looks at the pictures. Ha, ha.
P.S. Yeah, I had my lap belts at my side but they got anoying and it did not look clean, IMO.
Old May 27, 2003 | 07:32 PM
Reid's Avatar
Global Moderator
The fact that the Mugen axle back weighs more than the b pipe?
Old May 27, 2003 | 07:48 PM
IGGY's Avatar
Default Re: Installed my snap in kit. (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
The fact that the Mugen axle back weighs more than the b pipe?</TD></TR></TABLE>
Yes! That is what i found to be interesting! I could not believe this.
Old May 27, 2003 | 07:53 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">Yes! That is what i found to be interesting! I could not believe this.</TD></TR></TABLE>
Well that canister does look VERY heavy.
Old May 27, 2003 | 09:10 PM
Bob#455's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">P.S. Yeah, I had my lap belts at my side but they got anoying and it did not look clean, IMO.</TD></TR></TABLE>
Whoops...I sort of forgot about the little things that matter when you still have interior in your car.
Old May 27, 2003 | 09:13 PM
Bob#455's Avatar
I didn't say anything because it didn't really surprise me at all...the exhaust is noticeably heavier than stock. I think the b-pipe is close in weight to the stock one, but the axle back is probably about 10 lbs. more.
Old May 27, 2003 | 09:19 PM
IGGY's Avatar
Whoops...I sort of forgot about the little things that matter when you still have interior in your car. </TD></TR></TABLE>
We all forget about the little things sometimes.
RUBZERK
May 17, 2006 11:45 PM
xbladr
Mar 26, 2006 05:39 PM
ep3sir
Sep 12, 2003 02:19 PM
SamuraiX
May 8, 2003 02:02 PM
GreenBean
Sep 10, 2002 05:17 PM
