afc and 450's install car wont start
Old May 26, 2003 | 10:08 PM
krazyDOHC's Avatar
Default afc and 450's install car wont start
hooked up the turbo today...using afc with 450's tried starting the car at -35 and
-40 wont start....not gettin any spark for some reason..check the plugs and they were a little wet, not much
ps: at first i tried starting it with the 10ohm 10watt resistors on the the lead wire of the injectors-double checked directions, put them on neg wires...no blown fuses(could be wrong)
any help would be appreciated thanks!
Old May 26, 2003 | 10:14 PM
turbod16y8's Avatar
Default Re: afc and 450's install car wont start (krazySOHC)
u may have flooded ur engine with fuel.. try taking out your plugs and cranking it over a couopple of times. then reset the ecu then try to start her up..
Old May 26, 2003 | 10:58 PM
krazyDOHC's Avatar
Default Re: afc and 450's install car wont start (turbod16y8)
still wont start...double check wiring its all fine
Old May 27, 2003 | 01:05 AM
_Endless_'s Avatar
you might not getting any spark. try checking all your fuses in the engine bay and under the dash especially the ignition fuse under the dash.
Old May 27, 2003 | 05:40 AM
krazyDOHC's Avatar
Default Re: afc and 450's install car wont start (_Endless_)
checked them...still no spark....which fuses in particular are you talking about? ....ill go double check
Old May 27, 2003 | 05:51 AM
ash.zero's Avatar
if you unplugged the injector power clip, make sure that it's plugged back in...
Old May 27, 2003 | 07:33 AM
boosted_dc2's Avatar
Default Re: afc and 450's install car wont start (ash.zero)
if your not getting any spark then check your coil and/or distributor components. Just follow your helms and check for troubleshooting "not getting spark" this happened to me and it turned out my coil was bad
Old May 27, 2003 | 08:08 AM
rrei's Avatar
Default Re: afc and 450's install car wont start (hooked_up_gsr)
same thing happened to me when i did the hack i changed my spark plugs and it started up
Old May 27, 2003 | 08:22 AM
Evil EG's Avatar
Default Re: afc and 450's install car wont start (rrei)
give it some gas as its cranking.
Old May 27, 2003 | 11:49 AM
krazyDOHC's Avatar
Default Re: afc and 450's install car wont start (BVM)
ttt.....no spark! tried all the above
Old May 27, 2003 | 02:25 PM
you checked all ignition components??? was your vafc working before or did you do everything at once??? check all wiring at your computer and if that doesent work return it back to stock and see if it starts then
Old May 27, 2003 | 02:37 PM
scttydb411's Avatar
double check to make sure you have spark. pull plugs and wires and connect a plug to the wire and have some one give it a real quick crank. you will see a good spark. you might have washed your plugs and cylinders if you flooded it badly with your settings. similar thing happened to me. this may help:
https://honda-tech.com/zerothread?id=508621
good luck.
Old May 27, 2003 | 05:56 PM
krazyDOHC's Avatar
Default Re: afc and 450's install car wont start (scttydb411)
STILL NO DAMN SPARK....i uninstalled the afc and still, no spark, no blown fuses....i dont get it it!!!.....afc works fine
Old May 27, 2003 | 07:24 PM
scttydb411's Avatar
try new plugs. if they were wet you fouled them.
Old May 28, 2003 | 01:32 AM
_Endless_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC &raquo;</TD></TR><TR><TD CLASS="quote">checked them...still no spark....which fuses in particular are you talking about? ....ill go double check</TD></TR></TABLE>
it's a 15A fuse under the dash. this fuse blew after i installed my msd6a i thought i was doomed coz i can't find what's wrong so i checked the fuses i think relates to fuel and ignition and found that 15A fuse.
double check your afc wiring and check the calibration process.
Old May 28, 2003 | 06:14 AM
krazyDOHC's Avatar
no blown fuses and im not getting spark from the wires.....i am stumped ..afc wiring is good
Modified by krazySOHC at 3:32 PM 5/28/2003
Old May 28, 2003 | 07:10 AM
DBallz's Avatar
Check you ignitor it's probably blown it happens to everyone
desiromeo812
Dec 18, 2008 05:35 PM
sirjmj
Jun 21, 2008 09:06 PM
solk1dd
15
Feb 7, 2005 01:50 PM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
crxY-49
Sep 10, 2003 12:44 AM
