are stock spark plugs ok for the zc piston/d16a6 combo?
Old May 26, 2003 | 07:25 PM
altoid's Avatar
Default are stock spark plugs ok for the zc piston/d16a6 combo?
im currently building my d16a6 up with the d16a1/dohc ZC pistons. I've got the y8 head gasket (0.037in) and now im just picking off the small stuff, and this happens to be one of them. So are the stock plugs ok or should i get a colder rating and if i go colder what rating would you recommend?
edit: ooof nevermind its 11.09:1 i was using the wrong piston/deck clearance
Modified by altoid at 1:09 AM 5/27/2003
Old May 26, 2003 | 10:11 PM
daniboy4nspd's Avatar
Default Re: are stock spark plugs ok for the zc piston/d16a6 combo? (altoid)
wat piston/deck height did u use for that CR?? How do you know which piston/deck height to use??
Old May 27, 2003 | 05:26 AM
altoid's Avatar
Default Re: are stock spark plugs ok for the zc piston/d16a6 combo? (daniboy4nspd)
http://www.knology.net/~jediklc/D.htm
I used the DOHC ZC deck height. which is 1mm. The blocks are identical and the rods are the same length and the stroke is the same, just the zc piston is 0.5mm shorter. check out that site its helpful
Old May 28, 2003 | 08:28 AM
altoid's Avatar
ttt
GarageAlchemist
Jun 12, 2007 08:28 AM
pugsleeuk
Mar 31, 2006 11:35 AM
935CRX
Nov 28, 2005 09:04 PM
kcalb_3pe
Nov 26, 2004 03:53 PM
