Anyone with a CRX HF with D16Z6 please reply!
I'm currently swapping this engine into an 89 CRX HF. My question is, on the fire wall, is a black box which has the MAP sensor. The OBD1 TB has the map sensor on it. Do you just bypass this or not use the MAP on the TB?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt »</TD></TR><TR><TD CLASS="quote">use the one on the TB and obd1 harness plug..</TD></TR></TABLE>
Thats how I wired it, but I wanted to make sure before I put the engine in the car and have less room to work with. Thanks.
Make sure you trace the correct wiresf rom the ecu to use the map for. If not, you will have plenty of problems. We had it! Use the Z6 one though, and good luck.
drewboy
13
May 14, 2005 10:11 AM
