B20 Vtec
Old May 26, 2003 | 06:18 PM
redvic's Avatar
Default B20 Vtec
I was just woundering if the is any piston to valve clearence with the stock b20 bottom end and stock gsr head?
Old May 26, 2003 | 06:22 PM
VTEC-DA's Avatar
Default Re: B20 Vtec (accvolks)
Of course there is clearence. If you mean, are there any clearence issues, then no. It will work fine.
Old May 26, 2003 | 06:34 PM
redvic's Avatar
Default Re: B20 Vtec (VTEC-DA)
That is what i ment
Old May 27, 2003 | 08:27 AM
dElSleepiE's Avatar
no.. the gsr head will hit.. if you compare a b16/type r head to a gsr head.. the dishes for the pistons to clear where the valves are, are not shaved out all the way around.. youll notice on a b16 head it is a full ring around.. a gsr is not.. i would get someone who knows what thier doing to help you.. i just did b20vtec..
Old May 27, 2003 | 09:46 AM
MPower332TI's Avatar
Default Re: (_ApplePoop_)
Itll be fine as long as you dont go installing some adjustable cam gears and changing the cam timing. This is only with stock pistons though so once you get some nice pistons itll be gravy. Good luck.
OH and i wanted to add that applepoop was mistaken. The GSR head has square combustion chambers which yeild .2 more compression points than a B16 with a round combustion chamber. Has nothing to do with valve to piston clearance.
boostedb20ek
Nov 9, 2010 03:46 AM
97-crv-owner
Sep 18, 2008 07:42 PM
92_honda_hatch
Oct 5, 2006 11:16 PM
b20integrapower
Jan 31, 2006 10:34 PM
Carlo Gambino
Apr 5, 2005 11:11 PM
