B20 Vtec
no.. the gsr head will hit.. if you compare a b16/type r head to a gsr head.. the dishes for the pistons to clear where the valves are, are not shaved out all the way around.. youll notice on a b16 head it is a full ring around.. a gsr is not.. i would get someone who knows what thier doing to help you.. i just did b20vtec..
Re: (_ApplePoop_)
Itll be fine as long as you dont go installing some adjustable cam gears and changing the cam timing. This is only with stock pistons though so once you get some nice pistons itll be gravy. Good luck.
OH and i wanted to add that applepoop was mistaken. The GSR head has square combustion chambers which yeild .2 more compression points than a B16 with a round combustion chamber. Has nothing to do with valve to piston clearance.
Carlo Gambino
04-05-2005 11:11 PM
