looking for the right sized socket for my axle nuts
Old May 26, 2003 | 05:08 PM
4ghatch's Avatar
Default looking for the right sized socket for my axle nuts
does anyone know what size the axle nuts are on a 91 hatch dx? I need to pick one up and i dont know what size they are
Old May 26, 2003 | 05:20 PM
MAD SCIENTIST's Avatar
Default Re: looking for the right sized socket for my axle nuts (4ghatch)
32mm socket goto like pepboys there 32mm axle nuts
Old May 26, 2003 | 05:28 PM
FourthGenHatch's Avatar
Default Re: looking for the right sized socket for my axle nuts (MAD SCIENTIST)
Yeah it's 32. Stick the socket on a breaker bar with extension, make sure you popped out that notch on the nut, have someone stand on the brakes and just put your weight into it, it should come right off.
Old May 26, 2003 | 05:34 PM
Default Re: looking for the right sized socket for my axle nuts (FourthGenHatch)
or get yourself a black and decker bulldog electric impact gun its better than my matco air gun
Old May 26, 2003 | 06:31 PM
Hondasaurs's Avatar
Also, when you go to remove them, they have a crimp in the center of the bolt. You will need to pop this out. Just use a flathead screwdriver and a hammer to tap it.
Old May 26, 2003 | 11:15 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ghatch &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know what size the axle nuts are on a 91 hatch dx? I need to pick one up and i dont know what size they are</TD></TR></TABLE>
Well I hope that they are the original axle nuts or atleast size that is. Limozeen ran into a problem where the aftermarket axle nuts were like a 30 or 31? Dont remember the size exactly but it wasnt OEM.
Old May 27, 2003 | 05:15 AM
durrett syndrome's Avatar
Default Re: looking for the right sized socket for my axle nuts (Vinceg99)
or a 1 1/4 socket
Old May 27, 2003 | 08:38 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: looking for the right sized socket for my axle nuts (durrett syndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durrett syndrome &raquo;</TD></TR><TR><TD CLASS="quote">or a 1 1/4 socket</TD></TR></TABLE>
yulp
and like vince said.. could be a smaller nut.. see what they do when the treads get fucked.. they cut them down, then cut new threads.. thats loss of meat.. then they use a smaller nut.. sorta wack, but thats what they do for rebuilds. technicaly "it will hold"
for the most part, its 1 1/4, or 32 MM
pkolaboy
May 19, 2009 10:27 PM
EG6_978
17
Mar 18, 2009 10:16 AM
hondmywrld
15
Apr 21, 2008 01:34 AM
92greenwagon
Dec 7, 2004 04:24 PM
serious
Mar 9, 2003 04:40 AM
