how much gas in your tank? when you go to the track.
Old May 26, 2003 | 03:14 PM
fastwanabe's Avatar
Default how much gas in your tank? when you go to the track.
When I go to the dragstrip I usually have about less than 1/4 tank I wonder if this affects performance at all, whada you think?
Modified by fastwanabe at 12:28 AM 5/27/2003
Old May 26, 2003 | 03:18 PM
Sketch_hs's Avatar
Default Re: how much gas in your tank? when you go to the track. (fastwanabe)
less weight = faster car.
-Sketch
Old May 26, 2003 | 03:20 PM
t0p_sh0tta's Avatar
Default Re: how much gas in your tank? when you go to the track. (Sketch_hs)
Weight of One Gallon (U.S.) of Water, Gasoline, and Ethanol
1 gallon of water equals 8.33 lbs.
1 gallon of gasoline equals 5.8 to 6.5 lbs.
1 gallon of ethanol equals 6.59 lbs.
Source: U.S. Dept. of Energy.
Edit: I always thought that water and gas would have similar weights.
Old May 26, 2003 | 03:30 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">less weight = faster car.
-Sketch</TD></TR></TABLE>yes I understand the weight thing but I wonder if having a little fuel in the tank can actaully starve a motor of fuel when compared to like a 1/4 tank.
Old May 26, 2003 | 03:38 PM
t0p_sh0tta's Avatar
This is possible when your running on fumes and taking a looooong sweeping turn, but I don't think that you'll have to worry with a 20 second or less pass down the 1/4 mile.
Red_ED8
Sep 26, 2006 08:42 AM
MrIllegalX
34
Feb 21, 2004 10:02 AM
Civic44
Jun 3, 2002 12:29 PM
ITS BONE STOCK I SWEAR
Jul 31, 2001 10:27 AM
