easy engine swap for 1992 civic cx
Old May 26, 2003 | 03:13 PM
eludingu's Avatar
Default easy engine swap for 1992 civic cx
whats the easiest swap for a 1992 civic hb motor an tranny swap that wont cost a crap load of cash???? if ne 1 has aim or aol im me at PBRrolla i want a lota hp
Old May 26, 2003 | 03:14 PM
simplegreenmachine's Avatar
Default Re: easy engine swap for 1992 civic cx (eludingu)
D16z6 is my fav yet cheap swap....but if u want DOHC then iuno
Old May 26, 2003 | 03:29 PM
navin's Avatar
Default Re: easy engine swap for 1992 civic cx (MonKey Magic)
any motor is easy in a 92 cx..
b16a [sirII] and b18c5 would be drop in and no wiring with a chipped p28..
same with the b18c1 with skank2 intake mani + chipped p28
FYI - you already have VTEC wired into your main harness'
Old May 26, 2003 | 04:05 PM
GSR Dave2094's Avatar
I would say a ZC would be cool but then again ZC is a big swap for CRX or '88-'91 Civic's since they have a cable clutch. But sicne a '92+ Civic is hydro you could be different and go ZC and mate ti to a '92 Civic Si tranny. But as far as easiest jsut go with a D16Z6 you can get everything at once motor/tranny/ecu as opposed to buying a motor separate from the tranyn if you went ZC. But if you wan a godo motor that has DOHC VTec the nyou cna go B16 for cheap.
Godo luck!!
Poptart
Jul 10, 2006 04:52 PM
stock_cx
Dec 6, 2003 01:01 PM
dragonhaven2001
Jun 7, 2003 12:54 PM
aonick
Sep 29, 2002 10:57 AM
