? Competch Icebox Which filter?
For those of you using the factory black elbow with there Icebox, Which filter do you use from Comptech? The S2000 w/ a straight inlet or the GS-R with a slight bend in the inlet? Thanks
There is 2 cone shape with different bends They dont offer a new filter with the Si kit. They want you to buy the whole kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkoupe »</TD></TR><TR><TD CLASS="quote">For those of you using the factory black elbow with there Icebox, Which filter do you use from Comptech? The S2000 w/ a straight inlet or the GS-R with a slight bend in the inlet? Thanks</TD></TR></TABLE>
use the filter made for integra. theres only one to fit all 94+ models.
Damnn I ordered the S2000 Heres is what they said from Comptech
The ice box is just the box. You will need to purchase our short ram intake to work with it due to the way the tube is routed to the box and how the filter sits inside of it. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkoupe »</TD></TR><TR><TD CLASS="quote">Damnn I ordered the S2000 Heres is what they said from Comptech
The ice box is just the box. You will need to purchase our short ram intake to work with it due to the way the tube is routed to the box and how the filter sits inside of it. Thanks.</TD></TR></TABLE>
your car is integra right? don't know if other filters work, but i'd stick with integra filter.
Heres is the S2000 filter link.
http://solar.innercite.com/com....html
GS-R
GS-R
Heres the set up. 00 Si in a 95 Hb. I am using the ITR black elbow. I ordered the Icebox for the 00 Si. I was just wondering what kind of hole was on the back of the box and how it fits when you use the OEM tube
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkoupe »</TD></TR><TR><TD CLASS="quote">Heres the set up. 00 Si in a 95 Hb. I am using the ITR black elbow. I ordered the Icebox for the 00 Si. I was just wondering what kind of hole was on the back of the box and how it fits when you use the OEM tube</TD></TR></TABLE>
don't konw about other cars, but... you can use comptech box with factory oem elbow, and the only filters that will be a bolt-on are: comtpech integra filter, k&n filter, oem or local autoparts store replacement paper filter.
i'd think it would matter, based on what i seen in the picture of civic Si kit, inlet looks straight, but they inlcude their own elbow. on 94-01 integra, inlet has a bend to fit factory intake hose. i've seen 92-95 civics with comptech box and b series engine and stock intake hose, but don't remember what filter they used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkoupe »</TD></TR><TR><TD CLASS="quote">If you look at both filters does the bend at the inlet matter where it goes into the box? Is there room to play?</TD></TR></TABLE>
The bend doesn't even matter. The S2000 Filter is almost twice as large as the Integra Filter, it won't even fit in the Box as it is bigger than it.
Just get the Integra Filter and use the OEM Intake arm
HOLY **** THEY'RE SUPPOSED TO BE BLUE?????!!!??! I just cleaned mine and it went from a black to a kinda dark greenish color, should I just say **** it and order a new filter?
u need the one with the bend in it.. otherwise the OEM tube won't attach correctly cus is comes at an angle I just did the icebox/ filter with stock tube on my car.
eaglclon
Honda S2000
Nov 28, 2005 10:40 AM
Honda.F1
May 15, 2004 03:27 PM
EricUSC
Jun 8, 2003 08:48 PM
