filling tranny up?
Old May 26, 2003 | 01:35 PM
Nextelbuddy's Avatar
Default filling tranny up?
well i finished another swap in my car and i usually fill the tranny up with oil through the side with this special oil pump untill oil starts to drip back ou but now i dont have that tool right now and remember that i can fill the tranny up through the VSS hole. now i am going to do this but i dont know how much is too much when filling through that hole, i dont want to over fill it has anyone done this before and can tell me how i know when i have enough fluid in the tranny?
Evs-One's Avatar
Solbros Owns Me
Default Re: filling tranny up? (nextelbuddy)
it helps if you say what engine/tranny you have....
my D16Z6 takes 2 quarts....B18C5 tranny takes like 3.5 I believe
Old May 26, 2003 | 01:38 PM
Kamin's Avatar
Default Re: filling tranny up? (Emerika)
2 quarts for honda b and d series transmissions
technically for a b series its 1.8 at a refil 2.1 at overhaul.
dont know the exact d series numbers.
Old May 26, 2003 | 01:49 PM
Default Re: filling tranny up? (Kamin)
i have a b16 with my old type r lsd tranny S80. i leaked tranny oil from where my axles were because i had top replace the axle seals and i dont think its completely empty i just want to fill it back up throgh the VSS. is there too much oil in the tranny if i top it off through the vss, u know like if theres oil coming out of the vss hole ? or is that too much?
Old May 26, 2003 | 01:52 PM
Kamin's Avatar
thats way too much
remove the filler hole then fill from the VSS
when it comes out of the filler its full.
Old May 26, 2003 | 01:54 PM
ahh good call ok ill do that. i didnt do the above yet i was just thinking about it. but your way sounds right thanx man
Old May 26, 2003 | 02:03 PM
Kamin's Avatar
i know its right thats how its supposed to be done hehe
Old May 26, 2003 | 02:11 PM
Sketch_hs's Avatar
bahhh just ghetto rig a funnel and a tube with tape ba bam!
-Sketch
Old May 26, 2003 | 03:25 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">thats way too much
when it comes out of the filler its full.</TD></TR></TABLE>
yup . that's how i did it. after it started coming out of the side hole i poured about another 1/4 quart because you have to compensate for the tranny being tilted (since it's jacked up).
Old May 26, 2003 | 03:39 PM
bzyrice's Avatar
yup even the haynes manual says to wait for it to overflow through the top hole LOL ... before I changed it I was like WTF ... but it works and my tranny is fine
Corksil
10
Dec 12, 2009 11:38 AM
peep
Transmission & Drivetrain
May 10, 2009 11:46 PM
hatch_
Apr 17, 2006 05:05 PM
Honda Crx
25
Sep 20, 2005 10:08 AM
TURBO
Jun 29, 2004 08:12 PM
