what intake on EG?
Really any non-namebrand tubing will work, the filter will be the important part. Get a good K&N filter and slap in on the end of the tubing and that should do just fine.
_Brandon
_Brandon
im too poor to do a swap right know so i want to get an intake on my bone stock DX motor with stock exhaust. i plan to get exhast after the intake all just to let the motor breathe better. eventually ill do a swap. so i need help on which to get...AEM, INJEN...etc. thanx
get the OBX one, cheap and reasonably good. I just put it on my D15 and i saw some improvement, but common, do you expect to gain a lot out of this engine. I know i am not, no wonder why i am saving for the mighty B18c5. The main reason is just get a cheap one OBX and that is it. When you get the swap, sometimes, people upgrade to better intakes, so that is one reason i didn't spend much. I am planning on supercharging the swap. So go figure. Do what is best for YOUR NEEDS, just spend some bucks, save the rest for the swap...you'll need it. later.
JDM_WHR
26
Dec 27, 2009 10:26 AM
oovvutt
91
Nov 26, 2009 09:40 AM
biggdogg
11
May 7, 2008 09:12 PM
HUBB
May 26, 2003 08:47 PM
