Header Fitting
Old May 26, 2003 | 11:41 AM
MidoriEK4's Avatar
Default Header Fitting
right now im running a b20vtec with a jdm itr header the 4-1. anyways i couldnt get the header to go on. the header wouldnt fit under the pan (b20 pan). do i need a different oil pan for this header? say a gsr pan or civic 00 pan? any info would be helpful. thanks.
Old May 26, 2003 | 04:22 PM
T-rav EF9's Avatar
Default Re: Header Fitting (NA CRX Si)
Yes, Swap on a GSR oil pan and it should work. My friend had the same problem and he ended up going with the GSR oil pan and he said that it worked.
Old May 26, 2003 | 04:24 PM
MidoriEK4's Avatar
Default Re: Header Fitting (T-rav EF9)
what else do i need? pan and pick up tube? what about windage tray?
Old May 26, 2003 | 05:02 PM
MidoriEK4's Avatar
how about a b16 pan?
maxogsr
Jun 1, 2008 03:31 PM
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
92gsr1
Aug 15, 2005 05:01 PM
Shakes
Mar 28, 2004 07:25 AM
