Axles for B20Vtec?
im doing a b20vtec swap and i was wondering when installing the axles do they sit back from where the diff is to where they go into the knuckles? or is it suppose to sit straight? need some info on this. thanks.
look at your car from the side, you will notice the engine is definitely in front of the wheels, and the diff is in front of the knuckles by a bit. your setup looks like it is supposed to be.
I say it depends on the Mount kit that you're using. Some kits will give you a larger angle, because its position closer to the front of the car. Others will be less, but all-in-all a slight bent is normal.
see the thing i noticed is that when i moved the pass mount backward that the axle was about to hit the rear crossmember. how close is your axle in between the shock fork?
trooper0641
Apr 1, 2004 05:34 AM
DRKSol
Dec 14, 2003 10:04 AM
